394 Question Need help bad.
Old Mar 28, 2006 | 01:56 PM
SMOKEYMTNKUSTOMS's Avatar
Exclamation 394 Question Need help bad.
Bought a '62 Cotner Bevington Combo Car with the 394 engine. The front of the motor was off at the time and was missing a few parts. One part missing was the water pump pully, but included one that was in the back. When I tried to put it on the water pump it hit. My question is, is there a spacer or something that goes between the water pump and the pully? Is there also a spacer or something that goes between the fan and pully? I am so friggin' confused right now. I thought the pully was the wrong one and ended up buying a new one, but it fits the same way. Any help PLEASE!!!
Mike
Old Mar 29, 2006 | 04:42 AM
Oldsguy's Avatar
Past Administrator
I will try to check with my son, He has a '64 98 and he rebuilt the 394 in it a number of years ago. I will really try to remember and get back with you. Otherwise, If you do use a spacer you have to be sure that the belts all line up with accessories they drive, as far as a spacer between the pulley and the fan, I would think clearance with the radiator and fan shroud would determine if that is possible, maybe one was used to bring the fan closer to the radiator for efficiency...
BTW, do you frequent the HAMB?
odddoylerules
Apr 21, 2014 07:54 AM
airmale
Nov 13, 2013 11:15 AM
scooter123
Mar 22, 2012 10:21 AM
d rek
Aug 21, 2010 10:25 AM
