Dim brake/signal lights
Old May 29, 2009 | 05:53 AM
ggparts's Avatar
On the 69 Cutlass it has been noted that the brake lights are quite dim. Not sure if anyone else has had this problem, seems like lenses are discolored or foggy?
Any suggestions to clean them, or a source of new aftermarket lenses?
There is no issue with the blub brightness itself.
Old May 29, 2009 | 07:17 AM
Rdrokit's Avatar
I find that Wenol metal polish in the red tube cleans up plastic to make like new. Use on the inside and outside and they will look like new. Also check the contacts and grounds on your light sockets.
Old May 29, 2009 | 07:49 AM
ggparts's Avatar
Thanks for the reply
OK, I'll see if I find that stuff around here. I am fairly confident with the brightness of the bulbs in regard to the grounds.
thanks again
Old May 29, 2009 | 07:54 AM
Lady72nRob71's Avatar
If you have 12V to the bulbs with engine off, then the electrical part should be okay. When running, 13.5V is typical.
Many times the white or silver reflectors behind the colored lenses get dirty or rusty. I had to repaint some before...
Sometimes the lenses are dirty on the inside, too.
Old May 29, 2009 | 08:01 AM
ggparts's Avatar
Another great suggestion!
This place is awesome. I will check the relectiveness (is that a word?) inside the lamp housing.
Old May 29, 2009 | 10:10 AM
Rdrokit's Avatar
thanks again
If you can't find it locally you can order on line from their website. Just click on "Retail Sales"
http://www.wenol-polish.com/wenolintl.html
costpenn
Jun 24, 2015 10:38 PM
cheven
Aug 4, 2012 01:45 PM
pistonpop
Mar 27, 2012 08:26 PM
plee3 64Olds
Mar 24, 2011 08:47 PM
1972 X code 442
Jun 12, 2008 01:49 PM
