Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Headlight Switch
Old Nov 2, 2012 | 07:56 AM
wolvercote's Avatar
Headlight Switch
Now have all lights working with exception of instrument panel and right hand side above the glove box. Where the word OLSDMOBILE is. Do you think replacing the headlight switch will correct this? Or any other suggestions. I have replaced all the lights and connectors behind the instrument panel. Thanks
Old Nov 2, 2012 | 07:59 AM
wolvercote's Avatar
Headlight switch
Forgot to mention it is a 1962 Starfire. Senior moments are getting more frequent.
Old Nov 2, 2012 | 09:06 AM
Your panel lights could be out because of a bad rheostat in the headlight switch, or maybe because of a bad fuse.
I'd disconnect the wire from the headlight switch and connect it to a 12V source, and if the lights come on, the problem is in the switch.
gwunta
Jun 22, 2024 08:59 AM
brandon reynolds
Dec 18, 2013 03:05 PM
Neg
Nov 27, 2008 07:14 PM
Andrew240
Dec 3, 2007 12:43 PM
andyg
Jun 15, 2007 05:05 AM
