Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Frame woes.....
Old Aug 6, 2011 | 03:21 PM
64OldsSarfire's Avatar
Frame woes.....
So I finally got underneath my 64 Starfire for the first time. There was quite a bit of rust and rot, more than I was hoping for. Right behind the front wheels and in front of the rear wheels where the frame ties into those frame "boxes", they are completely rotted away. It looks as though I will be performing some frame surgery on the this vehicle. I'm not the happiest camper about this. and after I clean and inspect damage underneath, I pull it off the jack and go to pull it back in the garage and a brake ruptures. Great, this car is going to be more of a project than I anticipated.
Is it just me, or is this frame kind of a poor design?
Old Aug 6, 2011 | 03:23 PM
Here's the car.....
https://classicoldsmobile.com/forums...-starfire.html
Old Aug 6, 2011 | 04:30 PM
66ninetyeightls's Avatar
Land Yacht Captain
Frame rot is the worste. Normally I would suggest sourcing a better frame but that vehicle is likely to be a very tough find. I'm sure someone will chime in with more info though.
Old Aug 6, 2011 | 05:01 PM
Oldskeeper's Avatar
your running a 64 88 frame that is probably open (boxed frames were convertable or towing package) so if I'm right a 63-64 full sized 88 frame will interchange, a 98 frame can be shortened in the side rails to work.You should be able to get one from the mid west and do a swap.
Barring all that, patching a frame while still under the body is alot of work and you can't weld in some places and you will get twisting as the frame restresses after shrinking a cooling.
Steve
Old Aug 6, 2011 | 07:38 PM
Steve
Thanks Steve.....I don't know if I want to undergo a complete frame swap, Im going to try to section some parts out for the time being. ugh
sixty9olds
Body work
Feb 27, 2010 01:18 PM
sssingo
Nov 12, 2008 09:25 PM
Olds64
Ninety-Eight
17
Sep 8, 2008 10:16 AM
elmo
Dec 11, 2006 06:18 PM
Redog
Nov 15, 2006 05:20 AM
