Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
65 fullsize Cruise Control
Old Feb 26, 2009 | 05:40 PM
Specman's Avatar
Hi Olds fans,
Does any living soul out there have any working knowledge of the original equipment mechanical cruise controls in a 65 Starfire or fullsize 99/98? Is this worth fixing? What have some of you guys done with it? Where do I start?
Old Feb 28, 2009 | 06:56 AM
toro68's Avatar
My Dad worked on an A?C system for a 1965 Starfire ragtop a year ago.
He used to work on speed control units years ago.
HIs buisness is Auto/Air Inc
S. Portland,Maine 04106
(207) 773-8735 8-4 (will be open on Fridays, starting in April)
Gerard Russo Sr is the guy you wantot talk to.
Old Feb 28, 2009 | 06:57 AM
toro68's Avatar
Pau'ls red 65 Starfire conv is for sale by the way.
Old Feb 28, 2009 | 09:09 AM
rocketraider's Avatar
Oldsdruid
The 65 CSM goes thru the troubleshooting, calibration and regulator repair procedures, but I can't think of anyone offhand who refurbishes these old motor-driven DANA units, and lord only knows where you'd find repair parts. Try Alan Kriss in NJ, 570-376-3942. He does clocks, tube radios, speedometers and GuideMatics. He may be able to do something with your CC.
Up front- are you familiar with how it operates? Sometimes a misunderstanding of how it works is all that's wrong with it.
Old Mar 3, 2009 | 08:40 PM
bigoldscruiser's Avatar
2 '66 98's
The earlier 60's Cruise dash units are the same through 1966 but the under hood units are quite different. The 65 and 66 are the same. Depending on what your problem is, I may be able to help you. A common problem is the plastic gear that drives the speed setting cable in the dash unit. I have a friend who has had some made from aluminum. There isn't too much that goes wrong with the under hood unit except possibly the relay. I have a spare under hood unit laying around. How about some explanation of what it is or is not doing and maybe we can work it out. Bruce
Old Apr 2, 2010 | 01:18 PM
Burgundy Mist's Avatar
65 Starfire Cruise Control
I am refurbishing my dash and would like to cut the hole (in the lower left metal portion) for the control ****. Does anybody have a template for the location of this hole? Thanks.
mruders
Feb 4, 2014 08:15 AM
aliensatemybuick
May 5, 2009 07:36 AM
pontchief
Cars Wanted
Feb 17, 2008 01:14 PM
