72 rocket 350 cam install
Old Apr 12, 2013 | 04:12 PM
RocketPowered's Avatar
So by the looks of it this has been covered about 2,000,000 times but lets throw another one on the pile. I just purchased a 72 rocket 350 with 7a heads, an Edelbrock 3711 manifold and 750 cfm carb for my 85 cutlass. I'm going to be using a 3.73 rear gear and 2400 stall 200/4r and wanted to know if the comp cams xe kit would be a good choice to throw in before I put it in the car??? Or should I leave it alone??? I think it has everything in the kit except pushrods. Would I need different length ones??? Here are the cam specs:
Exhaust Duration at 050 inch Lift:224
Duration at 050 inch Lift:218 int./224 exh.
Advertised Intake Duration:262
Advertised Exhaust Duration:274
Valve Lift with Factory Rocker Arm Ratio:0.475 int./0.480 exh.
Any help would be greatly appreciated. Thank you!
Old Apr 13, 2013 | 01:27 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I'd use the xe250h instead. 72 engines just don't have the compression.....
Old Apr 13, 2013 | 09:02 PM
Thanks J. As far as the 3.73 rear gear goes do you think thats to short? The car isn't going to be a daily, just a cheap toy to take out and romp on every now and then.
Old Apr 13, 2013 | 10:15 PM
Tony72Cutlass'S''s Avatar
Whats wrong with the cam that you've got in there right now? i've got a stock 350 cutlass that can roast tires all day long.
Old Apr 13, 2013 | 10:19 PM
L69's Avatar
L69
I love the XE cams. Some will say the ramps r to fast and can cause some noise. But they sure produce a great amount of power.
Old Apr 13, 2013 | 10:22 PM
at 8.5:1 she still puts out a good punch!
I did a compression test last weekend, my lowest cylinder was 125 and my highest was 135, with 125,000 miles, i still can't see any reason to do a rebuild...
unless of course i came into some money, then i'd probably throw a 455 into there..
Old Apr 15, 2013 | 01:41 PM
There's nothing wrong with it to my knowledge. But its out of the car and on a stand and Im more trying to get at would it be worth throwing a cam in an engine that hasn't had a rebuild. Or should I just leave the cam alone and throw the engine in the car???
Old Apr 16, 2013 | 04:58 AM
3.73 would be nice with the overdrive. The cam swap will be well worth it so long as you do everything correctly.
Old Apr 16, 2013 | 11:37 AM
Ok got it. Thanks for the input guys. I'll keep you posted on the final outcome.
Old Apr 16, 2013 | 02:49 PM
Also, what kind of headers should I use for the swap???
Sampson
May 8, 2013 08:09 PM
KennyRain
Dec 17, 2012 11:11 AM
mechanicman81
Mar 3, 2011 07:35 PM
1969cutlazz
Jan 9, 2011 09:37 AM
70cutty
Aug 13, 2008 05:48 AM
