Magnetic Throttle Arm???
Old Sep 23, 2009 | 08:14 AM
dallasite21's Avatar
I have this little magnetic arm that connects to my throttle linkage and bolts onto the carb. It looks like it is supposed to control the idle someway. I beleive it is broken, but I dont know what it is called or what it does. Does anybody know this info. I have attached a pic showing the area it is in. Its a 71' cutlass 2 barrell 350 by the way.
Old Sep 23, 2009 | 08:37 AM
Lady72nRob71's Avatar
Hi Parrish,
I am thinking that is an anti-diesel solenoid. When ignition is on, plunger is extended, setting the throttle to idle position. When key is turned off, plunger retracts, throttle closes less than idle, and cuts off airflow so that dieseling / run-on is prevented or reduced.
Old Sep 23, 2009 | 08:42 AM
I think its functioning inproperly... it causes the car to idle high because it is pulling on the throttle.
Old Sep 23, 2009 | 08:53 AM
delmontcrusier's Avatar
67 heavy metal
that can be related to vacum lines if they are cracked broken or missing the engine will race at least that was the problem on one of my vehicles.
Old Sep 23, 2009 | 08:55 AM
gearheads78's Avatar
car guy
Idle compensator for when the A/C is on?
Old Sep 23, 2009 | 09:09 AM
Do you have an ohmmeter? Ohm it out to see if the coil is good and make sure the plunger moves in and out freely. If those both work, then trace back to what is supposed to be controlling it.
Old Sep 23, 2009 | 09:46 AM
Originally Posted by Lady72nRob71
Hi Parrish,
Correct.
It should not be "pulling" on the throttle. It should simply be a stop that the throttle arm comes to rest against. The solenoid should be energized at all times that the key is on and retracted when the key is off.
Old Sep 23, 2009 | 12:43 PM
Oldsguy's Avatar
Past Administrator
To elaborate on Joe's statement. If your idle is too high because of the device, then just re-set your idle speed according to your tune-up specs, the device isn't really causing a high idle, a mis-adjustment is.
Old Sep 24, 2009 | 01:52 AM
Bluevista's Avatar
Registered
I don't believe that is stock for a '71?, it should have a manual dashpot for anti-stall according to the manual.
Either an anti-diesel or an AC compensator as said. My '71 Vista Cruiser has the same engine and carb and my idle really drops when the compressor kicks in, an AC idle compensator wouldn't be a bad idea, maybe they had a dealer retrofit because of the problem?
My '68 poncho 400 has the anti-diesel solenoid stock and you adjust the plunger with a small/ignition wrench in or out after it's warmed up and off the choke, it looks just like your deal.
Old Sep 24, 2009 | 02:41 AM
jensenracing77's Avatar
i think we have some confusion here. (maybe just me and not we) on these cars i only seen the A/C cars have it for idle compensation. when the A/C is on it pushes on the throttle to compensate for the drag of the A/C compressor. i thought that the anti dieseling came later.
Old Sep 24, 2009 | 03:38 AM
Bluevista's Avatar
Registered
I know the anti-diesel solenoid is stock on my '68 GTO. The manual dashpot on the Olds is an anti-stall device used so the carb doesn't close too quick and stall the engine when you let off the gas suddenly as far as I know. I don't know when they started using the idle compensation deal for the A/C, didn't some cars older than '71 have them?
I know nothing about A/C but it seems like on the later units than mine the compressor cycled on and off along with that idle compensating solenoid you would hear clicking when the idle speed went up or down with the compressor cycles. The book just shows a higher idle setting for A/C in the book for mine. The 1971 6 cylinder has the C.E.C. valve on the carb and an anti-dieseling relay tied in with the A/C wiring, maybe it also increases idle speed with the AC on?
defiant1
Feb 4, 2020 08:53 PM
Vandy
Aug 18, 2015 05:44 PM
defiant1
Jan 7, 2015 04:59 PM
oldzy
Dec 19, 2011 06:43 AM
salisbury99
Jul 5, 2008 05:26 PM
