tranny swap and rear end ratio
Old Apr 22, 2009 | 07:46 PM
oldjunk's Avatar
Talking tranny swap and rear end ratio
Hi Guys!
I am restoring a 1972 cutlass S 2 door. I am replacing the 350 with a stock 455. I want to replace the TH350 transmission with an overdrive, either a 700 4R or a 200 4R. I currently have 2.73 rear gears, and I am wondering if this rearend ration will work well with the 4 speed. This car is going to be a driver, not a drag car. Any opinions are greatly appreciated.
Old Apr 22, 2009 | 11:42 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
It should work well for a cruiser.
The 7004r will need a chevy conversion mounting plate, and the driveshaft will need to be shortened.
2004R should bolt to the motor , but your transmission mount and crossmember may need to be moved back or swapped out for something else.
Old Apr 23, 2009 | 06:48 AM
Neither the 700R4 nor the 200-4R will survive in stock form. Since either one needs to be modified, the 200-4R is the easier swap. Your stock driveshaft will work fine. Your stock crossmember will also work fine, though you will need to move it rearward. Your frame is already drilled for this rearward location since it is the same as used on the TH400 that was available in 1972. You will need to get the throttle vavle cable and bracket from a 1980s Olds with the 307/200-4R combo.
Old Apr 23, 2009 | 10:55 AM
Thanks for the correction, Joe.
I do believe a 700r4 could survive fine if it is just a driver, though.
I'll have to get back to you guys on that one.
We just put a motor that ran 12.40's in front of a 700r4.
I'll let you know the outcome after the racing season is over, or as soon as it shatters into pieces.
Old Apr 23, 2009 | 11:28 AM
mugzilla's Avatar
is Fast Enough ...
With me I like having the trans as the weakest link as the labor and cost of a replacement are relatively cheap.
I'd rather break a trans than the engine or rear end ...
Old Apr 23, 2009 | 02:38 PM
X2
Old Apr 23, 2009 | 07:00 PM
oldjunk's Avatar
Thank you very much for your comments. What kind of modifications do you suggest I make to the 200 4R to make it more durable?
Old Apr 23, 2009 | 07:19 PM
88 coupe's Avatar
Junior Member
http://www.cpttransmission.com
Norm
Old Apr 23, 2009 | 09:38 PM
mugzilla's Avatar
is Fast Enough ...
I bypass the radiator and plumb the lines directly into the biggest transmission cooler I could find ...
Heat is the enemy ...
Old Apr 25, 2009 | 07:51 PM
jaysun's Avatar
ate glue as a child
some reading
http://www.turbobuick.com/forums/tra...ing-2004r.html
Old Apr 26, 2009 | 11:31 AM
mugzilla's Avatar
is Fast Enough ...
Originally Posted by jaysun
I'm checking the linkbacks. I am checking out interchanges like universal bell housings when this popped up ...
Originally Posted by megaladon6
i 4l60e, it's basically a 700 with computer control. plus, you can get the shifter paddles on the steering wheel
Kind of takes the hassle out of shifter locations...
Old Apr 26, 2009 | 01:55 PM
ThyPlumber's Avatar
Try a 4L60 should be reasonable on price, think the final drive ratio was around 0.60, dont forget to replace your spedo gear, might want a tranny shop to mach it up.
Old Apr 26, 2009 | 10:26 PM
mugzilla's Avatar
is Fast Enough ...
I use the guy that calibrates the chip speedos' ...
350TurBRO
Sep 12, 2014 11:52 AM
Aceshigh
Oct 22, 2009 06:55 PM
jonstringer
Drivetrain/Differentials
Oct 8, 2008 03:26 PM
American Lead
Mar 31, 2007 04:37 AM
benkerr
Aug 26, 2006 07:41 PM
