heat/defrost control panel modification
Old Jan 13, 2013 | 05:08 PM
68conv455's Avatar
The climate control switch on my 68 cutlass is broken. It seems the "off" position bracket broke on the back of the control unit. I'm planning to wire the gate in the air plenum open, then permanently disable the remaining "off" reature on the rear of the control unit.
It almost seems like an out of date feature anyway to permanently stop all airflow. I believe I will still be able to regulate the heat/cool via the heater door cable, and the force of the airflow using the fan switch.
The broken part is at the very rear of the assembly in the picture.
Can anyone think of a reason I shouldn't do it?
Unit has 3 cables. One for windshield/floor gate, one for heat/cool gate, and the damaged one for airflow/no airflow gate.
Old Jan 13, 2013 | 06:08 PM
allyolds68's Avatar
I'm not sure why you'd want to disable anything. I've got two or thtree spare ones. The thing that usually breaks are the plastic mounting tabs on the cables . Your cables look fine
Old Jan 13, 2013 | 06:15 PM
68conv455's Avatar
If anyone is interested in selling a good used unit, please post or pm me.
Thanks.
Old Jan 13, 2013 | 06:21 PM
allyolds68's Avatar
Thanks.
Let me look in the pile in the morning
Old Jan 13, 2013 | 06:34 PM
allyolds68's Avatar
Sorry, my two spare ones look like yours.
Someone must have a spare
Old Jan 14, 2013 | 07:32 PM
68conv455's Avatar
Removed the broken piece from the control tonight. Going to re-install in a few days without the off position.
OldsmobileKid
Oct 12, 2014 03:30 PM
marcoandersson
Sep 15, 2013 11:12 PM
hadafew
Apr 14, 2013 09:20 PM
hadafew
Feb 4, 2013 09:36 AM
bjtstarfire
Nov 13, 2008 02:04 PM
