1972 cutlass glove box lock removal
Old Nov 28, 2012 | 03:27 PM
rmoths's Avatar
I'm sorry to ask this question again, but I can't find the reply on this back.
I need to change out my glove box inner door, It's cracked. So I need to take the lock apart to get the inner door apart from the outer door.
I know there is something to press with a small screwdriver in a little window to get the lock apart. Well if someone can help out I would really apprciate it. Thanks Barb.
Old Nov 28, 2012 | 03:35 PM
RetroRanger's Avatar
72 Olds CS
https://classicoldsmobile.com/forums...1-cutlass.html
Old Nov 28, 2012 | 04:03 PM
rmoths's Avatar
Wink
[QUOTE=rmoths;480362]Thanks, but I don't seem to have the right key apparently. I only have two keys ignition and trunk, and the trunk key doesn't go in the door lock. So without the proper door key I can't get this apart. Well maybe I can get the inner door off some other way.
Thanks Barb.
Old Nov 28, 2012 | 05:41 PM
4424me's Avatar
If you take it to a locksmith they can make a key for it for cheap enough. I got three keys cut and i didnt have one for my glove box either and it cost me 25 bucks.
Old Nov 28, 2012 | 05:56 PM
72 Olds CS
I was able to remove mine w out the key by depressing each tumbler thru the hole
Old Nov 28, 2012 | 07:12 PM
Exactly - you basically pick it out one tumbler at a time. Not too hard.
Old Nov 28, 2012 | 08:11 PM
rmoths's Avatar
Thanks, I think I'll take it to a local locksmith and see what he can do. If nothing else I'll file the hole around the lock a little bigger so I can take the back of the door off.
Thanks again, Barb.
Old Nov 29, 2012 | 07:50 AM
rmoths's Avatar
Wink
Well I took my Dremmel and with a small bit I ground just enough away to slide the back of the door off. It looks OK, I just had to grind away just enough to get past the door latch. Barb.
bobb
Jan 13, 2024 04:49 PM
Pewter442
Dec 8, 2015 08:09 PM
goldie442
Aug 21, 2015 11:01 AM
costpenn
Sep 12, 2011 12:15 PM
Kidcutty
Jun 13, 2010 07:12 AM
