Painting dash and door panels...
Old Feb 21, 2012 | 01:37 PM
Curts1970cutlass's Avatar
Recently bought a 72 for parts mainly dash, but want to use door panels also. Problem is I had planned on going with black interior. Ive seen paints made to paint plastics and door panels. Any tricks or suggestions. New stuff is brown and would prefer black.
Old Feb 21, 2012 | 01:42 PM
Rickman48's Avatar
There's spray cans for interiors in black - check with a automotive paint supply store.
From experience, lightly scuff everything being painted, clean it, and put a few coats on 'rub' areas.
Old Feb 21, 2012 | 01:52 PM
Thanks. i will post pictures in a few weeks when I start the project. i know the process seems simple, i just just take your time and prep it so it doesnt look like a homeade job
Old Feb 21, 2012 | 03:20 PM
Gary's 2 442-S's Avatar
Gary
I changed my color on the dash from saddle to black, I use Sem Landau Black. I did not try it on the door panels had new ones made by Legendary.
Old Feb 21, 2012 | 03:23 PM
Redog's Avatar
I would use 600 grit!
I sanded my cluster pod with a rough grit and you can see the scratches. It annoys me so much.
Old Feb 21, 2012 | 03:39 PM
boondocker's Avatar
Where were you in '72?
I used a black upholstery paint from an auto body supply outlet and had the white color matched for all the brown to white plastics. I prepped the surface with paint reducer, the paint seems to have adhered well.
Old Feb 21, 2012 | 04:06 PM
Nilsson's Avatar
SEM is the best product out there for painting vinyl. Did my door panels and rear seat on my 68 three years ago and they still look fresh. Preperation is key and all that information is available on SEM'S website. If you want cheap use something else and take your chances.
350TurBRO
May 7, 2014 08:01 PM
eudaman
May 19, 2013 05:30 PM
soxfan
Jul 20, 2010 05:34 AM
ddx77
Jun 24, 2010 10:49 PM
chris83
May 25, 2010 02:58 PM
