Glove Box Lock Removal w/o Key
Old Sep 12, 2011 | 07:27 AM
costpenn's Avatar
Wanting to remove the glove box **** to clean and detail on a 72 A body - however the key I have does not fit the lock (it's unlocked now) Is there anyway to take it apart besides the method in the CSM?
Old Sep 12, 2011 | 10:30 AM
RetroRanger's Avatar
72 Olds CS
I saw that method in the CSM I didnt have a key either. mine was unlocked I pushed the latch portion all the way in one direction either towards the body of the lock or away from it ( i dont recall) and turned the **** as if opening the glovebox. In the "window" called out in the CSM I could see the retainer. I pushed it in w a pick and it all came apart sorry for the vagueness I forget stuff quick
Old Sep 12, 2011 | 12:15 PM
Exactly. If you turn the cylinder to the point where it would come out if you had the key, you can pick each tumbler past the stop, one at a time, as you pull it out.
Then you can take it to a locksmith (or use the CSM to figure out the parts and buy them online), and have it keyed to match your trunk key.
bobb
Jan 13, 2024 04:49 PM
goldie442
Aug 21, 2015 11:01 AM
rmoths
Nov 29, 2012 07:50 AM
yeahbuddy
Sep 21, 2010 02:42 PM
justagirlfromla
Mar 11, 2010 10:15 PM
