Turn Signal Replacement Issue
Old Apr 17, 2009 | 10:43 PM
Jolly Green's Avatar
Exclamation Turn Signal Replacement Issue
Hey guys. I replaced the switch alright so far but I am unsure about two things putting it back together.
1) Do I have to press-fit the center piece with the bearings and turn signal switch back on? And if so, how? Like a metal tube and mallet?
2) There are three screws that go thru the turn signal switch, thru the metal bearing assy, then trhu the outer casing, and into a metal ring. Each screw has a small spring on it. Tightening the screws increases spring pressure and draws the ring closer. How tight do I want these?
costpenn
Jun 24, 2015 10:38 PM
1BOSS83
Jun 30, 2014 11:40 AM
jpaulwhite
Aug 21, 2010 06:08 PM
JD72OLDS
Dec 2, 2008 09:41 PM
pinky
Sep 30, 2007 06:30 PM
