electrical problems
Old Jul 10, 2009 | 07:22 AM
1BadLass's Avatar
electrical problems
Trying to wire in a radio, but my yellow wire is always hot. It is hot at the "radio" fuse panel also. when tested with test light In the acc position it is the brightest but still is hot at all other times. where does this yellow wire get it power from..could this be voltage regulator problem? Also my alternator light stays on and the voltage regulator clicks when battery is hooked . Not to mention fuel gauge is past full and it is new tank and sending unit..im pretty sure the ground is okay. thak you guys
Jamie
Old Jul 10, 2009 | 07:50 AM
Lady72nRob71's Avatar
Some good answers have been posted here in your previous thread:
https://classicoldsmobile.com/forums...regulator.html
I moved it to the electrical section.
Old Jul 10, 2009 | 07:57 AM
Jamie
Jamie,
If you are talking about the yellow power wire to the radio, it should be switched with the ignition and only hot in the RUN and ACC positions. Either someone has mucked up the wiring or you have a shorted ignition switch. I vote for a wiring problem.
Old Jul 10, 2009 | 07:59 AM
1BadLass's Avatar
electrical
as in a new key and switch?
Old Jul 10, 2009 | 08:54 AM
The key cylinder is separate from the actual switch in 1972.
chasman414
Jun 25, 2020 07:05 AM
gypsy66delta
Oct 14, 2008 07:50 PM
njot33
Aug 20, 2008 02:57 AM
65topless
Jul 6, 2007 01:55 AM
jf857
Apr 28, 2006 07:24 AM
