1965 425 or Toro oil pan ID question
Old Jul 1, 2009 | 09:57 PM
longboardguy's Avatar
I have a 1948 Cadillac that has a 1965 425 olds engine in it. The dip stick is definatly not the correct dipstick but someone had ground a mark on it at the 5 quart level. I verified this mark with a fresh oil change. There is another ground in mark a little higher on the dipstick that may be a 6 quart level.
I would like to know how to determine if the oil pan I have is actually the original 5 quart pan for the engine or if it is a 6 quart pan for a Toro engine. What should I look for on the pan?
I really dont want to run this engine without enough oil in it nor run it with too much oil.
email me at: gwfisher@ca.rr.com
thanks
Dbechtel71
Jan 3, 2015 06:09 AM
Bob Kelso
Apr 9, 2012 01:17 PM
Oldsmaniac
Jul 27, 2010 04:45 AM
FixinIt
May 19, 2008 05:03 PM
