floor shifter problem
Old May 24, 2009 | 03:37 PM
fred franklin's Avatar
I have an 84' 2 door cutlass with the factory floor shift and console. I swapped engine and trans. (removed the 84' 307 and 200c and replaced it with a rebuilt 77' olds 350 and a rebuilt 77' TH 350 trans,)
the floor shift cable wouldn't work, I went to a 77' cable(too long)..I ended up removing ALL linkages and running a B & M cable directly...the cable works fine, but the car will start in Reverse and DRIVE and I have no reverse lights....
Has anyone ran into this kind of problem and, HOW did you fix it?
Help!!!
Old May 24, 2009 | 05:53 PM
Help!!!
Did you reinstall the backdrive rod that goes from the trans to the steering column? It is required to operate the backup light switch (which is in the column) and the mechanical lockout on the ignition lock cylinder (there is no longer an electrical neutral safety switch). If you did reinstall the rod, then it sounds like it is not adjusted properly.
Old May 25, 2009 | 08:41 AM
No, didn't reinstall the backdrive rod...we got rid of it...would you have any Idea where a could possibly purchase one?
Old May 25, 2009 | 08:45 AM
Oldsguy's Avatar
Past Administrator
Fred, welcome to CO and hope you locate the rod you need.
Old May 25, 2009 | 08:50 AM
according to my guy, we had to do away with the rods...I currently have the B & M cable, and everything that hooks to the shifter part on the trans.(I'm not close to a mechanic) I'm mechanically challenged so you might have to go step by step with me on this....
jon1957
Body work
16
Nov 2, 2018 09:10 PM
jstrits
Feb 7, 2016 11:33 AM
69CutlassAlex
Feb 9, 2012 05:26 AM
knighthawk
Mar 9, 2011 09:42 AM
olds4life
Feb 27, 2009 08:54 PM
