juggling trans question
Old Feb 8, 2009 | 04:55 AM
loosecannon39's Avatar
Question juggling trans question
Hi guys.
Just read a thread about using an early, non dual range hydro, on a later, 394 eng. The writer made it seem complicated. When did these engine go to external balancing from internal?? When was the last year the 371,394 used the hydro, before going to the slim jim?? Will the early non dual range trans hook up to the later dual range bellhousing and converter/coupling to avoid an unbalance condition?? This is about putting a 394, or maybe a 371, in a 49/50 Olds using the original trans.
Appreciate any input.
TKS
DAN
Old Feb 8, 2009 | 12:33 PM
Oldsguy's Avatar
Past Administrator
Dan,
Sorry, I can't answer you question but I wanted to welcome you to our site. I am sure you will be getting some good info soon.
Old Feb 11, 2009 | 10:05 PM
88 coupe's Avatar
Junior Member
Originally Posted by loosecannon39
........ early, non dual range hydro ........
Hydra-Matic (N-Dr-Lo-R) was used from '39 to '51, Dual range Hydra-Matic (N-Dr-S-Lo-R) from '52 to '56, and Jetaway Hydra-Matic (A different trans) from '56 to '60.
........ When did these engine go to external balancing from internal? ........
'49-'56 = neutral balance, '57-'64 = external balance.
........ Will the early non dual range trans hook up to the later dual range bellhousing and converter/coupling ........
Everything interchanges.
........ This is about putting a 394, or maybe a 371, in a 49/50 Olds using the original trans ........
Good choice.
Use your '50 flywheel. Have a competent shop transfer balance it to the 371/394 unit. You may need to use a pilot bushing with the later crank.
Norm
Flye
Apr 18, 2011 04:24 PM
64Super88
Transmission
May 15, 2010 07:24 AM
455Gbody
Aug 4, 2009 07:19 PM
Samson
Eighty-Eight
Mar 31, 2009 06:13 PM
delta881972
Aug 25, 2008 02:12 PM
