303/371/394 swaps
Old Feb 6, 2009 | 05:22 PM
loosecannon39's Avatar
Question 303/371/394 swaps
Question please.
regarding a 49/50 Olds w/303 eng. will 324/371/394 swap into this chassis without adapters?? Either just engine, or both engine and tranny from the later car????
TKS
DAN
Old Feb 6, 2009 | 10:23 PM
88 coupe's Avatar
Junior Member
Welcome to the site,
Originally Posted by loosecannon39
........ will 324/371/394 swap into this chassis without adapters? ........
Yes.
........ Either just engine, or both ........
Yes and yes
........ and tranny ........
I don't know anything about trannys.
Norm
Old Aug 30, 2010 | 10:44 PM
tranny
Been away a while, but the tranny thing is generation gap thing. I looked up tranny on the net, and it wasn't something I want in my ride...
DAN
Old Aug 8, 2012 | 05:40 PM
Nailhead 88's Avatar
Junior Member
help
Question please.
TKS
DAN
got a problem my 50 Olds 88 coupe had a 371 Olds just laying on the frame
held up at the rear with a chain no transmission no rear crossmember
so i figured why know keep it simple put a 55 Olds 324 with stock hydramatic they both were rebuilt and bolted together
i did not have a cross member so i got one from the junkyard it came out of a 50 Olds 98 ( this my be the problem?) not a 50 Olds 88
the length was ok it fit the frame
the rebuilt 55 Olds 324 had front & rear mount mounts on it
when i put the 324 in i couldn't get the mounts 55 rear mounts
to line up with the 50 Olds 98 X member
i bought new 50 Olds 88 rear mounts the angle on the cross member and mounts didn't line up
this is the 50 Olds cross member from a 50 Olds 98 - problem???
rear mounts green are 55 Olds black are for a 50 Olds 88
i'm not sure if a 55 Olds cross member has a different angle or what?
so if anyone has been through this swap what's the answer
Thanks for any help or what am i doing wrong here
Old Aug 10, 2012 | 11:31 AM
Tedd Thompson's Avatar
Nailhead,
I've personally seen a 371 mated up to a 55 slant pan hydro and I don't remember any major modifications. This was put in a 55 hardtop.The one to call would be Ross Racinghttp://www.google.com/url?sa=t&rct=j&q=ross%20racing%20engines&source=we b&cd=3&ved=0CFMQjBAwAg&url=http%3A%2F%2Frossracing engines.com%2Fc%2F11%2Foldsmobile-rocket-engines-early-catalog%2F&ei=b04lUMvKEcf7iwLukYGYDQ&usg=AFQjCNE00 GF-MP_R7kHcpal0z5e757-xuA&cad=rja they know most everything about adapting these first generation Olds motors. There are problems that can happen from the difference from the 371 being internal balanced and the 324 being externally balanced but I have seen and done this myself with no problems( maybe just lucky)but I've never adapted a slant pan to a 50 Olds I thought they took the same rear mount.
This thread is very old and in fact 88 Cope is no longer with us( deceased ) so I wouldn't hold my breath expecting him to respond.
You might try posting this in the vintage or transmission forum where a bunch of the earley olds guys hang out, they are trying to close out this forum and it gets little use....Tedd
Old Aug 10, 2012 | 12:56 PM
Junior Member
Nailhead,
Thanks for the heads up on 88 coupe Rest in Peace Norm
Tony at Ross said use the 50 mounts with the 324 but
that hasn't worked not sure what the answer is
vintage guys i'll try that
Thanks Tedd for the info
2blu442
May 11, 2014 05:38 AM
Blownolds
Dec 14, 2012 02:00 PM
TOOhep
Mar 28, 2009 11:33 AM
Nailhead 88
Oct 7, 2008 02:02 PM
