Harrison Radiator Tag Decoding
Side tanks have a different code stamped on each tank, that is different than the radiator as an assembly itself's code.
Mine is missing this stamped code tag that is crimped onto the passenger side tank, but I think my Harrison side tanks "IF" and "CI" are original.
Just trying to verify correct coded radiator in my Olds before big money is spent to re-core it.
A Harrison radiator is worth every penny! My 80 Cutlass had one from the factory that lasted 16 years before blowing out! My next radiator made it 13 months. They replaced it under warranty anyway and the replacement split on the seam and had to be soldered 6 months later. Finally I paid the price and got another Harrison. It lasted until I sold the car.
The quality of a recore is only as good or bad as the materials and craftsmanship of the shop that does it. As with any rebuild. In the late '80s I had a '65 radiator recored and they added side supports that weren't on the OEM units (leading to longer life) and that was thus *better* than OEM.
