SWITCHING FROM 455 TO 350
Old Sep 15, 2008 | 07:31 PM
442scotty's Avatar
I have a 65 cutlass with a 455...to switch to a 350 do I have to change the frame mounts or will it just bolt right up
Old Sep 15, 2008 | 07:42 PM
hamm36's Avatar
Deepens on who you ask. I think bolt right up. Might need different rubber motor mounts if you do not use the old ones. Only because manufactures have done something to them in the past couple years. Check thread on mounting questions on this web site. A few different opinions.
Old Sep 15, 2008 | 07:51 PM
Suggest you ask Joe Paedevaro. He's got expert knowledge and can give you great info on this. If he's surfing this site you'll probably get an answer tonight. Anyway(he's on page 12 of the members list under the letter J) Good luck with your project.
Just out of curiosity, why would you want to downsize from a 455? I have an Olds with a 350 and its a great motor, but if it were me I'd be keeping that BBO.
Old Sep 15, 2008 | 08:10 PM
442scotty's Avatar
my 455 is at the machine shop and Im looking at a 4500.00 bill to have a done right street motor...there is a guy selling a slightly used professionally built 350 for 1900.00 big savings...gas too...but the 350 has done some dragging with nitrous...sounds good though...about 5000 km
Old Sep 15, 2008 | 08:33 PM
dan2286's Avatar
The frame mounts and motor mounts will both work.
Old Sep 15, 2008 | 08:36 PM
442scotty's Avatar
thats good...I was wondering because I always see big block frame mounts advertised on ebay as if they were required
Old Sep 15, 2008 | 08:48 PM
dan2286's Avatar
I think thats one of the best thing about Olds engines. They are pretty much the same on the outside. I think the major difference on the bb is the deck height is taller and uses a wider intake manifold. There is alot of stuff that can be interchanged between bb and sb Olds engines.
Old Sep 15, 2008 | 08:56 PM
442scotty's Avatar
thats what i thought
Old Sep 15, 2008 | 09:26 PM
2blu442's Avatar
455 to 350
The key to it is use the rubber mounts that are designed for the metal cross member pads. If you have the original 330 metal pads or perches then they should have used the rubber mounts for a 330. If you mix and try to use 350 rubber mounts on 455 metal pads you may have a problem. I swapped a 350 with headers from one car to another that had previously had a 455 and didn't know I had to match the mounts. I spend an afternoon with a ball peen hammer trying to make the headers fit, and pulling out my hair wondering why they worked so well in the other car but not this one! They were both 1971 Cutlass's. I've got some 1964-65 projects but haven't played with the engines yet. I don't know if the frame mounting pads were different between the small block and big block of this vintage. But if someone else made the swap, they might have used newer big block mounts. All that to say it will be simpler if you can use the metal pads and rubber mounts from the 455. John
Old Sep 16, 2008 | 08:29 AM
In 1965, the big block and small block used the same part number motor and frame mounts.
Suggest you ask Joe Paedevaro....
Wow, I've had some wild spellings in my time but never with "e"s before...
Old Sep 16, 2008 | 12:53 PM
442scotty's Avatar
thanks for that info! u the man!
Old Sep 16, 2008 | 04:31 PM
Whoops! Sorry Joe. I was a little on the tired side when I put that together. My apologies, I know that a name is kind of personal and should be spelled right.
My bad.
Old Sep 16, 2008 | 04:54 PM
My bad.
No problem, I'm just pulling your chain. Believe me when I say I'm used to it (but NEVER with an "e" before...)
Wyze
May 14, 2010 01:29 PM
shopaholic07
Aug 4, 2009 08:19 AM
cutty
Dec 16, 2008 03:46 PM
geckonz08
Aug 7, 2008 07:33 PM
nice72
Apr 7, 2008 06:26 AM
