NEW CARBERATOR
Old Jun 30, 2008 | 04:49 PM
southcarolina803's Avatar
71'OldsCutty
NEW CARBERATOR
my friend is sending me a holley 600 4 barrel, currently i am running a rochester 2 barrel, what parts to i need to convert this?
Old Jun 30, 2008 | 06:49 PM
JATA's Avatar
Well for starters you will need a 4-barrel intake, or a way to adapt the 4-barrel to the 2 barrel intake. You will probably require different linkage, fuel lines, and other hardware. What engine do you have?
Old Jun 30, 2008 | 06:57 PM
The_Jeremiah's Avatar
you need a new intake if you want to see any benifit from the 4 barrel upgrade, you will need to reroute the fuel line, and most likely have to redo the throttle linkage, you will have to make sure you have your vaccum advance hooked up right, lots of holleys have special ports for the distributor, but knowing the engine would help LOL
Old Jun 30, 2008 | 07:12 PM
71'OldsCutty
factory 350 that came in the 71 cutlass
ah64pilot
Sep 19, 2012 10:55 AM
ah64pilot
Aug 17, 2012 02:36 PM
dschallock
May 12, 2011 09:01 AM
Sam Barrett
Nov 4, 2009 06:46 AM
southcarolina803
Jul 2, 2008 07:14 AM
