Edelbrock Carb
Old Jul 31, 2009 | 01:50 PM
tim72's Avatar
Edelbrock Carb
I am running a 1411 edelbrock 750cfm carb. with a 455 bored 40 over and edelbrock heads. I believe I need about 825 to 850 cfm. Can I make adjustments on this carb to achieve it? No Carb sight so I put it here.
Tim72
Old Aug 1, 2009 | 11:15 PM
88 coupe's Avatar
Junior Member
Originally Posted by tim72
........ Can I make adjustments on this carb to achieve it? ........
No.
Norm
Old Aug 2, 2009 | 03:06 PM
tim72's Avatar
Originally Posted by 88 coupe
No.
Norm
Norm what would you sugest for a carb then? I am running a performer intake. I have a rochester? Can I get the cfm from a Rochester?
Tim
Old Aug 2, 2009 | 03:09 PM
tim72's Avatar
No.
Norm
I guess the only way to know if my 750 is to amall is to try another carb at the track?
Tim
Old Aug 2, 2009 | 07:19 PM
442scotty's Avatar
What makes you think you need more carb?...I have the same carb on my 455...040 over 9.5 -1 pistons...No edlebrock heads but C heads all done up.
I had to lean mine out...too rich...they are adjustible with jets and rods in a kit...if you use a air fuel guage for the adjustments you can get it to run real nice...Mine is awesome ...
Old Aug 2, 2009 | 07:58 PM
tim72's Avatar
Found a problem with the accelerator pump. It was torn. Guess the ethanol doesn't do the rubber any favors. Still a lot of folks say the best carb is either a Rochester or Holley.
Old Aug 3, 2009 | 05:07 AM
agtw31's Avatar
you could find a Buick 800cfm quadrajet,and have it built by your specs.
cores are around for $50-$60,it would run you some change to have it built right,though.
Old Aug 3, 2009 | 06:29 AM
tim72's Avatar
Thas what I am looking for. Actually any early 750's will run ok if rebuilt correctly from what I hear.
Old Aug 3, 2009 | 09:22 AM
64Rocket's Avatar
800 or 850 Holley is the way to go. Easy to tune.
Make sure your fuel pump can supply the sys. you need 5 to 7 psi fuel pressure.
Gene
Old Aug 3, 2009 | 12:23 PM
tim72's Avatar
Gene
Gene,
Looked into the holley and the guy there said the Holley 750 hp or avenger 770. I have not heard a lot of good things about the avenger. So go with a mechanical ?
Tim
Old Aug 4, 2009 | 08:30 AM
citcapp's Avatar
I run a Holly 770 avenger on my 455 10.5.1 compression edelbrock heads full roller cam, rockers. Runs hard no hesitation. Its all in the carb tuning no matter which way you go
69CutlassAlex
Jul 30, 2013 08:18 AM
70Cutlass_408
Jun 24, 2011 07:55 AM
#1CutlassSupreme
May 14, 2008 04:28 PM
fearthisrocket
Feb 18, 2008 06:19 AM
Huron
Jul 9, 2007 11:56 AM
