Getting nowhere
Old Apr 21, 2009 | 07:06 AM
wolfman98's Avatar
Captain of my ship
Getting nowhere
I need to find an answer to a question that I have had no luck on in the tech forum. I plan on running 10-40 for oil and as far as fuel the highest octane I can get is 91 that is non leaded high test I am planning on using octane booster and was thinking of adding lead substitute to help with my original 455 valve seats. I get a little bit of clattering noise on acceleration from the valves and someone on this site had mentioned that adding ATF fluid to a tank of fuel will help quiet the valve noise. Because of pollution concerns , lead substitutes have become hard to find around here so the question is will ATF fluid in the fuel replace a lead substitute?? And if so how much should you add to a tank of fuel for my 1969 Olds 98 convertible??
Old Apr 21, 2009 | 07:31 AM
Danielle's 71's Avatar
ya'll come back now....
this was a problem i just had i added about half a qurt and it has help alot!
Old Apr 21, 2009 | 07:38 AM
68Tom's Avatar
Use this stuff for your lead substitute. It's excellent and a bottle lasts a long time. It's one measurement cap full per 10 gal of gas.
http://shopping.msn.com/prices/cd-2-...-32-fl-oz-4298
Old Apr 22, 2009 | 11:36 AM
Burning_Rubber's Avatar
Marvels Mystery Oil always worked well for me. I keep a gallon jug of it in the shop all the time. Its great for keeping the rubber parts your carb and fuel pump lubricated also. think its like $12 a gallon at Walmart, you only need 4 ounces per 20 gal of gas so it last along time. Its great for stikky valves too.I run it in the oil and gas.
Old Apr 22, 2009 | 12:21 PM
wolfman98's Avatar
Captain of my ship
cd-2
We used to be able to get the cd-2 stuff here but as of a year ago i have not seen it , may have to look at ordering. Marvel mystery oil is one I have not heard of but we have a Walmart not far away , I will see if they carry it at the canadian walmart , regulations up here keep getting tougher to wade through. Thanks for the responses
brownalteza
Jun 12, 2015 08:36 AM
jaunty75
Oct 28, 2013 10:36 AM
Somwan
Suspension & Handling
Jun 13, 2012 04:36 PM
Moofinator
Ninety-Eight
28
Jun 4, 2007 09:13 PM
muttmeg
Ninety-Eight
Apr 21, 2007 09:26 PM
