Turn signal flasher ?
Old Jul 30, 2007 | 12:32 PM
JPDPG's Avatar
Hello, I'm a new member and new to classic cars, I just bought a 1967 Olds 442 all orignal... The hazard lights were flashing slow, so, I replaced the signal-stat 175 (green) flasher with a after market replacement, now they work great..crazy question, the turn signals still flash slow, I want to replace the flasher but I can't find it. The fuse panel has what or where it should have been, but nothing there, I can here the tick tick under the dash somewhere but can't locate it. Thanks for your help ! Great forum ! Patrick
Old Jul 30, 2007 | 01:16 PM
The hazard flasher is on the fuse panel, but the turn signal flasher is on a pigtail under the dash. Why that one was made more difficult to reach is one of life's mysteries. It should be held in a spring clip on the lower lip of the dash just to the side of the steering column (though I'm afraid I don't remember which side of the column).
Old Jul 30, 2007 | 03:28 PM
JPDPG's Avatar
Thanks, I found the hazard flasher in a spring clip with a pigtail connection just above the ebrake release rod to the left, nothing on the fuse panel, you can see where it should go on the panel (the plug configuration is there but it appears to have no electical connections in it) Checked again under dash with no luck. I'll keep at it ...Thanks
jpaulwhite
Oct 5, 2023 05:10 PM
costpenn
Jun 24, 2015 10:38 PM
cargo442
Sep 11, 2010 06:55 AM
DarrylJ
Apr 12, 2009 04:37 AM
Flye
Apr 7, 2009 02:34 AM
