Reverse Lights not working
Old Oct 3, 2009 | 06:35 AM
kimberlies7's Avatar
Kimberlies72
My 72 olds had column shift and now converted to floor shifter, My reverse lights are not working ...Any suggestions?
Old Oct 3, 2009 | 07:26 AM
Bluevista's Avatar
Registered
Did you re-install the linkage between the trans and steering column to activate the reverse light switch on the column/lock the shifter when in park with the column??
Where's your neutral safety switch?
Here's an illustration from the '71 assembly manual. The regular or dual gate consoles require a different shift lever on the trans, same as the regular column shift auto but with a tab for the shifter linkage/cable.
Old Oct 3, 2009 | 07:51 AM
4-ever-olds's Avatar
I had the same problem in my 70 Supreme after switching to a console. I had to turn the portion of the steering column by hand to get the reverse lights to go on. I didn't bother trying to reconnect the column shift linkage as I figured for the few times that I actually needed the reverse lights I could just do it by hand.
Old Oct 3, 2009 | 10:59 AM
svnt442's Avatar
Old Oct 10, 2009 | 03:45 PM
Kimberlies72
Thanks Olds guys!!!
71 Cutlass
Sep 11, 2010 11:57 AM
silverriff
Feb 13, 2008 03:59 PM
black betty
Dec 21, 2007 12:13 AM
Calvin.Norris
Nov 27, 2007 06:08 PM
<KEN>
Sep 22, 2004 08:39 PM
