Fuel Sending Unit-Ground, 67
Old Mar 23, 2009 | 04:01 PM
Flye's Avatar
67 442
'new' purchase. on a lift right now, so I tried to do a brief walk around.
gas/fuel sending unit:
appears there is a ground wire that bolts/connects to the tank strap bolt.
The end going back to the unit is broken off. I assume this was to ground the sending unit.
Is it a hard connection (soldered) back to the sending unit or was it a slip connector over a tab? or other?
I'm trying to figure out if I can crimp a connector and reattach, or I'm looking at having to pull the sending unit to fix it.
-OTHER: Is there a schematic or diagram of the sending unit setup online? I've ordered a service manual for it, but it may be a week or more before it gets here.
Thanks,
Old Mar 24, 2009 | 05:27 AM
Oldsguy's Avatar
Past Administrator
Is there any way to take a picture of this? I think they used a terminal lug under one of the mounting screws on one end (is that the end you say is broken off?).
Old Mar 24, 2009 | 06:42 AM
Flye's Avatar
Can't get picture today.
It is bolted to tank strap to ground to car. The wire then hangs loose, which I assume was supposed to be connected to the sending unit in some fashion.
Old Mar 25, 2009 | 08:55 AM
ricdiculus's Avatar
I think there was a .250" male quickconect tab that was part of the locking ring for the sender, or it might have been on the sender/pickup plate itself. when i pulled my tank on a '57 88 to install a return line, I neglected to reconect this wire and lost the gauge. In my case the only fix was to drop the tank to get to the sender/pickup plate since there was no other place to connect a ground to the tank. Once the ground was reconnected all was well. Without that ground, the sender has no way to make the signal to 'send' the information to the gauge. The tank usually wont ground just through the mounting straps.
Old Mar 26, 2009 | 12:54 PM
Flye's Avatar
It evidently is picking up enough ground somehow or another as I put some gas in it, and the needle came up the appropriate amount.
Old Apr 2, 2009 | 11:09 AM
ricdiculus's Avatar
and maybe it will ground through the mounting straps... But that may become an intermitent connection. Long story short, I wouldnt worry about it unless the gauge starts acting strange. The wire would just make sure you have a good ground path in addition to whatever is grounding it now.
Oldskool84
Oct 10, 2014 06:21 AM
pfergy600
Oct 4, 2014 05:29 PM
JPMDaddy
Oct 20, 2013 08:21 AM
m371961
Jan 17, 2013 12:21 PM
