1955 88 rear ?'s
Old Mar 25, 2008 | 09:28 AM
80C3's Avatar
1955 88 rear ?'s
Hello all,
I am in the process of restoring a 55 super 88. Would anyone happen to know what kind of rear came in this car, how wide of a rear wheel that can be run, and if anyone has fitted rear disc brakes on this rear? Any help is greatly appreciated.
Dave
Old Mar 29, 2008 | 06:56 PM
88 coupe's Avatar
Junior Member
Originally Posted by 80C3
........ what kind of rear came in this car ........
Manufactured by Pontiac. Used in Pontiacs/Olds from '54 to '56.
........ how wide of a rear wheel that can be run ........
A measuring tape, and straight edge, can be used to find the distance between the existing tire/wheel and the frame/wheelwells.
If needed, a bottle jack and 4x4 can be used to gain an extra inch,or two, at the outside of the fenderwell.
........ fitted rear disc brakes on this rear? ........
I doubt anyone would have reason to.
Norm
Old Apr 6, 2008 | 02:04 PM
Tedd Thompson's Avatar
1955 tire size
I run P235/60/R15 on my 55 convertiable any more and you will scrape one way or another.If I were to do it over I would drop one size in width. I like the stance that the 60 series tires give my car but the extra width is mostly lost under the wheel skirts and it would be nice to have the fronts and rears the same.By the way 235 are almost 9 inches wide.Hope this helps.....Tedd
flatoz
Brakes/Hydraulic Systems
Sep 9, 2022 03:15 PM
Hal Robinson
Feb 17, 2013 09:15 PM
rkolsen
Dec 22, 2012 01:42 PM
Tedd Thompson
Apr 12, 2008 05:24 PM
American Lead
Drivetrain/Differentials
Mar 31, 2007 04:37 AM
