1962 Rocket 88 Wheel Information Needed
Old Jun 22, 2007 | 07:43 AM
bob p's Avatar
Rocketeer
Hi. New member to the board. I own a 1962 Rocket 88 sedan.
I'm looking for the original wheel specifications. Specifically, I'm trying to find the rim size, offset, and bolt circle specifications for the OEM rims.
Going one step further, I'd like to know if I can temporarily use the original rims and the current 205-75-R14 tires from my Rocket 88 to transport a 1957 Chevrolet. I know that the tire size is right, I just don't know if the rim offset and bolt pattern are compatible.
FWIW, I have already checked my 1962 Olds Owners Manual and the 1962 Service Manual, but I haven't been able to find the rim offset and bolt pattern information.
thanks!
Old Jun 23, 2007 | 08:23 PM
Danny Wiseley's Avatar
Your Olds wheels should be on a 5-inch bolt circle; the Chevy needs a 4 3/4-inch bolt circle.
Old Jun 23, 2007 | 09:05 PM
bob p's Avatar
Rocketeer
Thanks. You're right, the Chevy spec sheets do say that it uses a 4.74 inch bolt circle. I wasn't sure about the Rocket 88. I was hoping that there might have been some consistency along the GM lines, but I guess that wasn't the case back in the 50s and 60s.
On a technical note, can you tell me if this is the method used to measure the bolt circle diameters as we've been referring to the measurements? I'm not confident in my own measurements, so I thought it would be a good idea to double check.
Thanks.
Mr Shifty Sidney
Nov 25, 2021 03:55 PM
doordoctor
Oct 27, 2014 07:16 PM
electra483
Oct 11, 2014 05:42 PM
Flye
Mar 18, 2013 07:03 PM
majcutlass
Nov 21, 2008 02:22 PM
