No problems just tried something that gave me good results
Old May 14, 2007 | 07:55 PM
olds307owner's Avatar
Okay guys, I dont want you to laugh but I tried something that I had never done before. Before when I would cruise I would reach temperatures of 195 to 200 using a 180 thermostat. At high speeds the same thing would happen. This weekend I sprayed water with a water hose through the radiator. A bunch of dirt and insects started coming out of it. I did this until the water came out clear. Yesterday I went cruising again and the temperature stayed at 180. Havent tried it at high speeds yet, but Ill post result later.
Old May 15, 2007 | 01:18 AM
ztim's Avatar
Good idea! I'll try it too. Good work.
Old May 15, 2007 | 04:58 AM
Oldsguy's Avatar
Past Administrator
look at shaks442 clone pics of his engine/car under the Cutlass section. On the heater supply hose coming off the water pump you will see a fixture that allows you to flush the complete engine. If you haven't put a coolant additive in your water I suggest you put one of those in and flush the engine. You can buy them almost anywhere. Good preventive maintenance item.
Old May 16, 2007 | 11:54 AM
I actually already added a coolant additive. Didnt drain the whole engine though just the radiator. Orange water came out. The additive I added supposedly restored antirust agents in the cooling system. Which additive do you recommend?
Old May 16, 2007 | 12:47 PM
Oldsguy's Avatar
Past Administrator
I can't as I just buy whatever catches my attention. Some guys buy "water wetter" and swear by it, others simply use a good "anti-freeze" (which I am sure you know is really a mis-nomer).
Old May 17, 2007 | 07:48 PM
Thanks for the suggestion, I will try it ASAP
chasman414
Jun 25, 2020 07:05 AM
coppercutlass
Apr 26, 2014 03:29 PM
zimmstoy
Aug 6, 2012 08:46 PM
67Olds442X2
Dec 16, 2011 11:45 AM
67Olds442X2
Aug 21, 2011 07:22 AM
