Axle installation and Lube.
Old Sep 4, 2008 | 04:47 AM
ziff396's Avatar
Well, I finally have some time to re-install my axles. While cleaning the housing, I noticed what looks like bearing races setting back 15/16" from the end of the tube. They are dirty so they are not part of my original bearings. Are these stops? My new bearings and seals measure 1 1/4". So does the seal "squash" as it is pressed in?? Just trying to be careful.
It is a posi and I will get the GM additive. What gear lube do you recommend?
Thanks again
Kevin
Old Sep 9, 2008 | 05:19 PM
ziff396's Avatar
RE
Thanks for any answers experts!
The actual measurements are 15/16 and my setup on the axles is 1 1/8 after close checking.
I was hoping you guys would be more informative. Sorry, but I am very detailed on things. I could have given you .001 measurements but I thought that was close enough.
Thanks Again!
boese1978
Feb 14, 2014 10:56 AM
White Spyder
Jun 17, 2012 12:53 PM
coreyshu
Brakes/Hydraulic Systems
Sep 4, 2008 09:38 AM
ziff396
Drivetrain/Differentials
Aug 26, 2008 05:18 PM
Lady72nRob71
Mar 12, 2008 05:31 AM
