axle bearing retainer
Old Mar 30, 2008 | 06:09 AM
Bunser's Avatar
I was wondering where I could find axle bearing kits, for a 70 Cutlass with a 12 bolt rear end? I can probably get the bearings by cross referencing the nos. and I think I can get the seals, but I don't know where to get the "retainer." Anybody know?
Old Mar 30, 2008 | 07:37 AM
Run to Rund's Avatar
What retainer? Instead of a bearing and retainer being pressed onto the axle shaft, the c-clip type axles have the bearing and a seal pressed into the housing, and the shaft rides directly on the bearing.
Old Mar 30, 2008 | 10:22 AM
Bunser's Avatar
Hmm, seems I had the same conversation with the guy behind the parts counter.There is NO clip.You are perhaps thinking of a Chevy or Ford rearend.The original retainer is a pressed metal affair, removed by careful use of a chisel.You then replace it with a solid metal "retainer." If anyone knows where I can get one, please post.
Old Mar 30, 2008 | 04:09 PM
Dapapadon's Avatar
Are you talking about the metal collar that goes on the axel shaft after the bearing? If so, the last several sets of bearings I've bought had the collar/retainer included with the bearing.
Don
Old Apr 18, 2008 | 09:21 AM
monzaz's Avatar
axle bearing retaining collar
Bunser, I have this same problem and i build diffs...lol. You can not buy them seperately. you ahve to buy the whole bearing set to get that collar. Well at least I have not found anyone yet that sells them. SO if you find a supplier please let me know...lol.
That is your answer...you have to buy the whole SetA9 bearing or RW507CR sealed bearing. crummy huh.
Good luck , Jim
jdrace.com
Old Apr 21, 2008 | 03:12 AM
Bunser's Avatar
I was able to get bearings,collar and seals from Supercars Unlimited. (www.supercarsunlimited.com) ORDERS (only) 1-888-OLDS442
Phone (503) 641-1442
They seem to know their stuff! Would recommend them.
ps
Bearings and collar came as a set...wouldn't sell separately.
muscle car resto
Drivetrain/Differentials
May 26, 2015 07:44 PM
62 Olds
Mar 24, 2015 06:51 PM
BackInTheGame
Jun 8, 2013 07:50 AM
mbrae5
Sep 5, 2012 04:15 AM
Flye
Jul 30, 2009 10:24 AM
