G body vs A Body Rearends
Old Aug 6, 2004 | 12:57 PM
<72S>
Guest
Posts: n/a
Question
Would an 8.5 10 Bolt from a G-Body (1984) work in a 1972 Cutlass A-Body? I understand that the '72 has a 10 Bolt (8.5?), but it's a 3:08 open diff. The 8.5 is a 3.73 Posi. Could I swap the G-body rear into the A-body?
Old May 21, 2007 | 08:28 PM
GoldOlds's Avatar
I could be wrong here, but I think most G-body ('78 to '88 Cutlass, Monte, Grand Prix, Regal, Malibu, etc.) rears have 7.5" rear ends, not 8.5". The 7.5" is the weakest rear end GM ever made. The only G bodies that had the 8.5" rear were the 442s and Grand Nationals/Turbo Regals.
Old May 22, 2007 | 09:45 AM
While there are a few 8.5 inch axles under G-body 442s and Turbo Buicks, almost all came with the 7.5 inch axle that was originally born under the Vega. More importantly, the G-body axle is about 3 inches narrower than an A-body axle AND the control arms are at a different angle. You can physically force them into place but the suspension will bind up if you try to drive it.
Old May 22, 2007 | 11:16 AM
GoldOlds's Avatar
That's exactly where those P.O.S. rears belong! Too bad the G-bodies didn't ALL come with the 8.5" rear - otherwise, they're great cars.
- GoldOlds
Old Sep 13, 2007 | 09:06 PM
monzaz's Avatar
8.5 rear
What I could never figure is how camaro and trans ams got totally left out of the 8.5 loop??? That was weird. JUST a thought. Jim
Old Nov 24, 2010 | 07:01 PM
Rickman48's Avatar
Someone was making control arms for the 12-bolt into a G body - don't know if it'll work the opposite way, though!
If that's watcha got to play with - make it work!!
HotBoy RuNNA
Drivetrain/Differentials
Feb 12, 2011 05:57 AM
mmurphy77
Jun 13, 2010 01:05 AM
hurstoldz
Sep 22, 2009 06:33 PM
74omega
Dec 28, 2008 06:53 AM
