how do you tight up the valves
Old Apr 21, 2008 | 11:52 AM
CLAUSAKOCH's Avatar
How do you tigten up the valves on a 350 oldsengien ???
I have a click in one of the valvs can i tight it up or is ther only one way to do it bay a new pushrods
Old Apr 21, 2008 | 12:54 PM
Oldsguy's Avatar
Past Administrator
Stock Olds rocker arms are not adjustable.
Old Apr 21, 2008 | 03:20 PM
Oldsmaniac's Avatar
Since there is no adjustment the usual cause is a worn rocker arm and pivot. You should replace as a set. It could also be a worn lifter or pushrod but the rocker is the most likely cause.
swesson
Oct 11, 2011 05:08 AM
boondocker
Aug 22, 2011 08:01 AM
knighthawk
Suspension & Handling
Jun 12, 2011 09:28 AM
mugzilla
Sep 16, 2009 08:25 PM
