New to site and have some questions
Old Feb 27, 2008 | 11:21 AM
Sully69's Avatar
Question New to site and have some questions
I have a 69 Olds Cutlass and I need a couple of things.
Windshield wiper arm for the drivers side
Question: Did a 69 Cutlass come with shoulder belts? Mine has them, but they look after market.
Where is a good place to get after market or original parts. (fenders, etc)?
Thanks in advance.
Dean
Old Feb 27, 2008 | 04:28 PM
Thanks in advance.
Dean
Wiper arm should be the same on all 68-72 GM A-body cars.
Front shoulder belts were federally required starting in 1968, so yes your 69 came with them. The 68-72 front shoulder belts were actually completely separate from the lap belts. The part that attached to the roof was not retractable and is stored with two chrome wire clips on each side just above the side windows.
There are no repro fenders for the 68-69 cars, just Chinesium patch panels that require considerable work to make them fit correctly and look good. Other repro parts are available from the usual Olds suppliers (Fusick, Supercars, etc). N.O.S. parts are few, far between, and priced accordingly.
Old Feb 28, 2008 | 07:10 PM
Sully69's Avatar
Thanks for the info.
You said Fusick, Supercars, Etc. Can you tell me more about the "etc"
Fusick was a good lead.
What is the best thing to do about those rusting fenders. The car is about 98% perfect, as far as rust goes. It's just the two front fenders, right behind the wheels. Any thoughts before it gets to bad?
Old Feb 29, 2008 | 07:01 AM
That's a very common rust spot on these cars. Failing finding good used fenders, your only option is patch panels. All of these patch panels are stamped at the same one or two Chinese factories, so shop around for the best price. Here are some sheet metal vendors:
http://store.shermanparts.com/cgi-bi...an/mgflist.htm
http://www.autobodyspecialt.com/
http://www.showcars-bodyparts.com/cutlass.html
http://www.billionsandtrillionsinc.com/olds.asp
As for the general resto parts, try these:
http://www.yearone.com/
http://www.opgi.com/indexhome.asp
http://www.usapartssupply.com/
cheffernan
Oct 13, 2012 05:38 PM
Fakser
Jul 22, 2010 01:54 PM
silverriff
Apr 13, 2010 06:36 AM
The_Jeremiah
Aug 2, 2008 08:39 PM
JustBurn
Nov 6, 2006 02:19 PM
