92 Cutlass Ciera 3300
Old Aug 28, 2007 | 09:20 AM
adelsin's Avatar
This car right here is great and reliable. Rated 170ish hp at crank, but sadly it doesn't see anywhere near that. Which leads me to my question, what can I do to let my tires see some more action?
Of course I can add more hp, but I feel that when the Transmission eats 35% of my HP, something else need to be done. Would and automatic shifter help? Or maybe a 4 speed tranny? It's sitting with a 3 spd right now. Let me know. I'm willing to do just about anything to make this into a mini-sleeper.
Old Aug 28, 2007 | 11:46 AM
adelsin's Avatar
B&M Automatick Shifter
I'm wondering about this right here. Made for TH350. and Mine is THM350. Any difference? Also, what's the difference between using this, and just cycling through 1,2,D ?
Old Aug 28, 2007 | 03:46 PM
Redog's Avatar
I'm sure there is stuff out there for that motor. RSM racing.com used to be pretty good, but I don't think they are in business anymore. The 93 Camaro used the 3400 motor, you might be able to get some parts for that motor and could help you a lot.
Do some reseach. Also check Summit and Jegs
Old Aug 29, 2007 | 10:31 AM
adelsin's Avatar
3400 vs 3300
3300 is a chopped down 3800. With that being said, it is also a 90*. 3400 I believe is a 60*. If anything would be compatitable, it would be the 3800. But are they cross-compatitable? If so, I'm slapping a SC on it.
Old Aug 29, 2007 | 10:45 PM
Redog's Avatar
The 3100 and 3400 are 60* motors, but the 3300 I'm not sure of.
I always thought it was another one in the 60* family, but if your reseach is right and it's in the 3800 fam, go for the s/c
Old Aug 30, 2007 | 08:05 AM
Uh, bolt them to a different car? (sorry)
Seriously, the 3300 is a smaller version of the venerable 90 degree Buick V6, most commonly seen in the 3800 version. As others have pointed out, the 3100 and 3400 are versions of the old 2.8 liter Chevy 60 degree V6. Completely different motors, nothing interchanges.
While engine swaps are possible (a supercharged 3800 comes to mind), this is a LOT of work that requires you to become intimate with the computer programming and wiring for the EFI. The simplest solution is a wet-flow nitrous kit.
65B01Delta
Mar 22, 2013 05:11 PM
Oct 25, 2012 10:55 AM
blevans3
Jul 1, 2012 02:20 PM
bermuda
May 18, 2006 11:38 AM
Big Dave
Dec 15, 2005 12:02 PM
