87 cutlass 231 engine
Old Mar 11, 2007 | 06:32 PM
slipbakka's Avatar
Hello everybody im a newbie.I have a 1987 cutlass 2 door i love the 231 engine that came with it.But i want some more horsepower out of the engine. do buick 231 parts fit on the engine.like the edelbrock intake and camshaft or im dreaming of getting performance parts for the engine.please i need help i like the engine i have.
Old Mar 12, 2007 | 02:17 AM
Jim's rare 80's Avatar
Jim's rare 80
Hi. Welcome to the forum. I believe the 231 in your Olds IS a buick engine. According to my book, the 231's were built by the Buick Motor Division of GM. The motors went out with a bang in the 87 Grand Nationals. I've seen lots for them, From 4bbl intakes, to headers. Check out the parts for sale section on this site. The best of luck with your ride. Jim.
Old Mar 16, 2007 | 02:24 AM
Dread
Guest
Posts: n/a
Im a newb also.. swapping my Buick 231 for a olds 307, if you want more power i would suggest an engine swap. You can basically put any engine in your car. An olds 307, 330, 350, 400, 425, 455. All will fit. A chevy 305, 350...etc will also physically fit, as well as the buick v6.... Just make sure you have the right engine mounts for whatever your trying to fit in. Any olds v8 can use the 307 mounts. Also you likely have a crappy 200c transmission in that thing if it came original with a v6. If your gonna put a powerhouse behind it, you might want to change that too.
Check out my thread:
Here
Old Mar 16, 2007 | 04:42 AM
Oldsguy's Avatar
Past Administrator
Dread, I am not so sure that the 307 mountst will fit on all the Olds Rockets. Also, the buick tranny will not bolt up to an Olds Rocket. How did your swap with the 307 go? Did you run into any troubles?
Old Mar 18, 2007 | 11:49 PM
Dread
Guest
Posts: n/a
Post
im still working on it... between skool and such its been hard... but we took out the original engine 2day....
Dasaki
Aug 3, 2015 03:15 PM
QS442
Jun 30, 2015 04:17 PM
85oldsman
Mar 25, 2011 11:02 AM
Redog
Sep 21, 2010 01:02 PM
slipbakka
Mar 15, 2007 06:42 PM
