Drivers side rear end sagging
Old Jul 12, 2009 | 05:32 PM
case2273's Avatar
71 cutlass convertible, frame on restoration, front end completely redone. Have not put it on the road yet. My drivers side rear end and front end appear to be lower than the passenger. No frame damage, southwest car, no rust. Why is it this way?
Old Jul 12, 2009 | 05:37 PM
Nilsson's Avatar
Have you replaced the coil springs on all four corners? If not I suggest doing so and if you have recheck your installation.
Old Jul 12, 2009 | 05:54 PM
Lady72nRob71's Avatar
Coils springs tend to sag over time and weight, just like springs in mattresses. The weakest one will show a sag first.
My 72 vert has a slight list to starboard. Looking under it, I saw the rubber spring insulator at the top of the spring is half missing. The whole rear suspension will be replaced soon.
Old Jul 13, 2009 | 07:33 AM
When you torqued the suspension bolts, was the weight of the car on the wheels? If not, the rubber suspension bushings can be "locked in" at the wrong suspension height, leading to ride height problems. On the other hand, if these are the original springs, it may be time to replace them.
Old Jul 13, 2009 | 07:45 AM
wmachine's Avatar
Trying to remember member
I was going to say that I have that same problem, but then I saw that you are talking about your car.......
Old Jul 13, 2009 | 09:20 AM
citcapp's Avatar
HA ha ha ha ha ha ha made my day
Old Jul 13, 2009 | 12:26 PM
case2273's Avatar
I have not torqued everything down yet because I noticed the stance problem. I have about 2 inches difference in the rear and about an inch in the front. Both on the drivers side.
Old Jul 13, 2009 | 01:06 PM
Nilsson's Avatar
That's messed up, was it like this before you rebuilt the front end? Might be able to help if you were more specific as to what you replaced and did not replace.
Old Jul 13, 2009 | 02:10 PM
72 cutlass455's Avatar
Check the shocks I had a set of Air shocks that fully extended the passenger side rod in the shock then seize up found this out after replacing the old springs with new ones.
Old Jul 13, 2009 | 08:42 PM
Yellowstatue's Avatar
Smile Speedy
Sounds like your car is set up for oval track racing
Old Jul 14, 2009 | 12:54 AM
Rdrokit's Avatar
Wow that is weird. Usually if say the front passenger side spring was bad that side would sag and on the rear it would bring up the divers side,like a fulcrum. BUT if you had larger diameter tires on the rear and then when you reinstalled them you put them both rear tires on the front & rear of the passenger side then the passenger side would be higher. Did you replace the springs on the front or all four corners?
Old Jul 14, 2009 | 12:02 PM
case2273's Avatar
I replaced everything rubber related on the front end before I dropped in the 350. The fenders bumpers and such are off the car. Just the frame, motor, body and such together. My garage floor is dead flat and I measured the frame with a tape and a level while lifted and stands adjusted and set in the same place. Tires are all good, rear end is level. No shocks on the front yet. Springs were set in correctly. Have not done the rear suspension yet. Noticed this first and decided to analize first. Rear shocks are not air and move freely.
Old Jul 15, 2009 | 12:21 AM
Rdrokit's Avatar
You lost me there, sounds like the car is on jack stands
Old Jul 15, 2009 | 01:53 PM
case2273's Avatar
car was on jackstands to take weight off of the springs to check and see if frame was twisted. Front end was not on so I could at least verify the front of the frame was true in various spots. If it is easy to take out the rear springs I am going to try and swap sides and see what happens. I have taken measurements with the car up and the car down. Sagging is definitely happening when a load on it.
Old Jul 15, 2009 | 02:43 PM
I done the rear of my 72 cutlass in about a hour i used spring compressors for safety sake.
Old Jul 15, 2009 | 02:52 PM
oldsonharmont's Avatar
When I had the suspension checked on my 71 cutlass convertible, there was a slight difference in ride height. My shop suggested a 1/2" spacer on the bad spring. I haven't tried it yet, but it could be a low cost fix for yours.
Old Jul 16, 2009 | 02:02 PM
case2273's Avatar
I have those but 2-1/2" is a bit much. Even the top isolation pad is only about 1/2". I am going to check the springs for cracks.
davoaz
Jul 20, 2014 06:29 AM
brown7373
Apr 21, 2012 12:49 PM
projectheaven
Suspension & Handling
Jan 4, 2012 09:32 PM
pakrat
Body work
Jul 11, 2009 10:20 PM
Willidog
Mar 29, 2009 11:41 PM
