68 exhausting mani!
Old Mar 24, 2009 | 06:58 PM
jackalack's Avatar
68 exhausting mani!
Allright olds exprts..looking to replace Lh exhaust mani on my 68 cutlass s has 350..went to that great olds graveyard Desert Auto in phx.& they r trying to sell me a mani but the valve? & spring r missing/or welded?off or open on the extreme lower rt corner of manifold. What does that sensor or ? Do? Can I do without or demand another more complete mani? Jackalack
Old Mar 24, 2009 | 07:02 PM
jackalack's Avatar
Mine has a small post & a spring mechanism the junkyard replacement is missing broken/cut off
Old Mar 24, 2009 | 09:46 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
that thing sucks anyway.
run it without the flapper door
Old Mar 25, 2009 | 02:56 AM
Yellowstatue's Avatar
Smile Hot stuff
That thing is the heat riser valve and it is closed when the motor is cold forcing hot air under the carb to help with better warm-up running and the curly spring thing is a bi-metal strip that relaxes when things warm up and the valve opens slowly or wide open depending on your foot... I have hedders so I don't have that problem... but I am still looking for a repair kit for my convert
Old Mar 25, 2009 | 12:11 PM
jackalack's Avatar
Cool,Thanks gents!Now if I can just get my mani off w-out snapping off any bolts!
Old Mar 25, 2009 | 12:43 PM
Bluevista's Avatar
Registered
We welded or brazed (the mechanics actually, the real kind that could fix things) those open and put manual chokes on cars with heat risers reguarly when I worked at one of several gas stations in the 70's. All I know is the automatic chokes that worked off a heat stove or tube or whatever they had wouldn't work right afterwards, maybe from carbon clogging up the crossover or not enough heat?
Me was grease monkey, no touch car engine, only oil filler cap and drain plug. Me only use two inch long wrench or me tighten plug too much and strip.
I've found the exhaust manifold bolts come out a lot easier if the engines warm, the hotter the better. I use anti-seize when I put them back together, you never plan on ever having to take them out again.
Eddie Hansen
Dec 15, 2014 06:26 PM
85cutlass6.6
Jan 28, 2012 10:49 AM
joe_padavano
Vista Cruiser & Wagons
Jul 12, 2010 10:52 AM
sacramento
Jul 28, 2007 07:03 PM
sacramento
May 7, 2007 11:33 AM
