alignment/caster setting help
Old Apr 22, 2013 | 09:18 AM
tmaleck's Avatar
I had a set of tubular arms installed on my 67 and the alignment specs are now in question. The stock setting calls for -1/2 to -2 degrees caster. These arms are the 'caster improving' type. The car is currently at +.9 left and +2.8 right.
The car wanders big time now, I can't hold a straight line at any speed. It was fine with the stock arms, even with worn out parts. The left side is shimmed like crazy to get the .9 degrees.
Global West says caster should be positive 5 degrees give or take with the new arms. Does this make sense?
Thanks,
Tim
Old Apr 22, 2013 | 10:32 AM
Run to Rund's Avatar
The factory specified slightly negative caster so the car would be easier to steer, especially with manual steering. I set my car at zero caster.
Thanks,
Tim
Yes. Caster is a trade-off of directional stability vs. steering effort. More positive caster will improve directional stability and steering feel but will increase steering effort. Hurst used this trick on the 1970s H/Os to improve steering feel (something like +4 deg of caster). Of course, your other alignment adjustments need to be in spec as well.
Old Apr 22, 2013 | 12:05 PM
Yes. Caster is a trade-off of directional stability vs. steering effort. ore positive caster will improve directional stability and steering feel but will increase steering effort. Hurst used this trick on the 1970s H/Os to improve steering feel (something like +4 deg of caster). Of course, your other alignment adjustments need to be in spec as well.
X2 - It helps your car to go straight, without having to constantly correct.
Old Apr 23, 2013 | 06:29 AM
oddball's Avatar
With aftermarket arms you need to use new alignment specs - NOT STOCK. Call Global West, get some alignment spec suggestions from them and take it back to the shop. Tell the guys to use the specs you give them and ignore the book.
71POWER
Suspension & Handling
38
Aug 28, 2018 08:00 AM
snylften
Feb 20, 2016 05:58 PM
1970-W30
Feb 18, 2015 05:29 PM
biggus
Jan 4, 2015 10:11 AM
Joah_from_Alberta
Jun 9, 2013 03:12 PM
