Preferences on rear trailing arms
Old Mar 23, 2013 | 12:40 PM
68vaolds's Avatar
I'm going to be replacing the rear upper and lower trailing arms on my 68 Cutlass S and was wondering which supplier is better and has a better cost.
Old Mar 23, 2013 | 05:07 PM
If your going to replace just the bushings for a stock application, I would suggest using moog parts through your local parts house, or rockauto. That would be the most economical route.
Old Mar 23, 2013 | 05:38 PM
68vaolds's Avatar
I was actually thinking about replacing with either QA1 or UMI over stock.
Old Mar 24, 2013 | 07:10 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have the spohn arms, however I can't write a rave review about them, because the center adjustable rod is too short in my opinion. The ends are nice, but I didn't like the center piece.
Old Mar 24, 2013 | 09:22 AM
As a structural engineer, I can tell you that putting the adjuster in the center is the absolute WORST possible thing you can do. That's where bending loads are greatest, so the last thing you want to do is to put an adjustment screw there that's smaller in diameter than the rest of the arm. The screw is now the most compliant part of the arm and it pretty much negates any stiffness benefit from the rest of the arm. Note that most arms or linkage rods that are weight optimized for stiffness have a WIDER center section and then narrow down at the ends where the adjuster is located.
Niko
Sep 15, 2014 01:43 PM
HonestDave
Mar 31, 2012 06:33 PM
leepear
Feb 13, 2012 04:21 PM
oldzy
Jul 4, 2010 07:53 PM
