Yet another '67 cutalss spring question
Old Feb 25, 2013 | 07:38 AM
67BB's Avatar
We have a '67 cutlass non-air with a big block. I believe it has the stock springs (SB) as it's bouncy. I'm new to cutlasses (cutli?) so here's the deal:
I have no idea what stock rates are. It looks like ~300 for SB? I haven't seen any for a BB other than the 442. I'm needing to know, do I buy springs for a 442? Is that wrong? It has a little rake now that my wife wants to keep. Should I go with BB springs that lower it 1"? Again, I have no idea what part number this would be. I see I can get Moog just about anywhere at a decent price. I have no idea what I need looking at the chart. I just need a part number. If you can give me a part number for stock I can hopefully figure it out from there.
One other thing that may or may not matter. Right now it has 205/75/15s on the front. She is going to 235/60/15s.
Old Feb 25, 2013 | 07:47 AM
There are quite a few recent threads pertaining to springs, rates and where to find them.
That tire should be fine depending on rim offset.
Old Feb 25, 2013 | 07:51 AM
67BB's Avatar
Well, I see for a 67 with SB or 67 442. I don't see any on any of the forums specific to a SB converted to BB. And deciphering springs rates and and charts......I just want a part number. If I have to do all that what's the fun of belonging to a forum?
Old Feb 25, 2013 | 07:54 AM
I have a bbc in mine and raised it front and back.
This is what I used:
https://classicoldsmobile.com/forums...front-end.html
Old Feb 25, 2013 | 07:59 AM
67BB's Avatar
I've seen yours over the past few weeks. Very nice. I just don't think she wants it raised.
Old Feb 25, 2013 | 08:26 AM
67BB's Avatar
I guess the easiest way to ask this is will a set of 442 springs work and put it at the stock height for a 330 cutlass?
Old Feb 25, 2013 | 08:36 AM
Opgi uses the moog pn's:
http://www.opgi.com/searchpart.asp?s...x=0&submit.y=0
And u can use the moog site to compare:
http://www.moog-suspension-parts.com...il_Springs.asp
Old Feb 25, 2013 | 01:59 PM
A 442 is simply a Cutlass with a big block. Order the 442 springs.
Old Feb 25, 2013 | 02:33 PM
67BB's Avatar
Ok, and that seems logical. So logical that's what I thought. But all the threads I see about a 442 is people saying they rode higher than the cutlass so.......
And which are the 442 springs? Really folks, just looking for a part number. 5234? Will that be higher? I'm looking for stock small block height. Is there a difference? I don't know but that's what I keep reading here. I'm pretty good at reading charts and those are about 300lb. Don't I need 425?
Maybe if somebody could just tell me what spring rate, height and install height I need I could figure it out.
Old Mar 1, 2013 | 04:48 AM
67BB's Avatar
Its hard for me to believe nobody has an answer other than here's a chart, figure it out yourself. Has nobody done a SB-BB conversion and changed springs? Really? Oh, well. Thanks.
Old Mar 1, 2013 | 05:01 AM
67BB's Avatar
Maybe somebody could tell me the stock specs for SB springs and BB springs? Since I don't know that yet a chart is meaningless to me. Thanks.
Old Mar 1, 2013 | 06:06 AM
Call yearone I know some people have gotten springs from them. I believe they use Eaton.
http://eatonsprings.com/index.html
Old Mar 1, 2013 | 06:23 AM
67BB's Avatar
Thanks for that. I will.
In the meantime can anyone tell me if the chevelle and cutlass take the same spring?
Old Mar 1, 2013 | 06:31 AM
Yes they do. All A-bodies use basically the same type of spring. Watch the end styles.
Old Mar 1, 2013 | 06:49 AM
67BB's Avatar
Well that was easy. Ground Up has the very thing I need then. I will call them and make sure both ends are tangenital if that's the right word. The picture looks squared off on one end but that's probably not the actual springs.
kitfoxdave
Jan 6, 2013 06:16 PM
Frank3
Oct 1, 2012 07:28 PM
coppercutlass
Mar 20, 2012 04:14 AM
cutlass xombie
Aug 20, 2011 07:01 AM
nonhog
Jan 23, 2009 01:09 PM
