rear sway bar 68 cutlass
Old Feb 8, 2012 | 11:21 AM
Charles Ludwick's Avatar
has anyone used one of the aftermarket rear sway bars that do not require boxed control arms that are available on ebay for around $125 ??
are they any good ??
will it really help the handling???
Old Feb 8, 2012 | 12:32 PM
boese1978's Avatar
Years ago I bought a 68 Cutlass that the guy had simply bolted a sway bar on to the un boxed control arms ( they came with the holes in them) and by the time I got around to actually looking, the control arms had cracks and "splits" raidiating from the bolt holes. They are just too weak IMHO. I can't say anything about the handling as that car was a rust bucket with 'nary a whole busing to be found so it handled poorly anyway.
Old Feb 8, 2012 | 12:48 PM
allyolds68's Avatar
Would they help, sure.
I'd need to see the link you're talking about but there are inserts that are very close to what was done on a factory boxed arm that can be welded into an unboxed arm so you can bolt a sway bar without crushing the arm. Maybe someone is putting that together in a package with a sway bar now??
edit:
$29.95 at chevelle.com
Here's a link to how to box a set of control arms
http://www.leverfamilysite.com/Boxin...ntrol_Arms.htm
Old Feb 8, 2012 | 12:59 PM
jensenracing77's Avatar
i little off topic but did you by any chance get that 68 out of Chicago? that looks exactly like a car i sold there about 5 years ago with 14,000 miles and the top pulled off.
Old Feb 8, 2012 | 08:01 PM
nope,, its a california car ...
here is the sway bar link from ebay
http://www.ebay.com/itm/64-77-GM-Bod...item5adf371a0d
Old Feb 9, 2012 | 06:27 AM
allyolds68's Avatar
A factory sway bar (less than $100) and welding in the inserts I show above are slightly more money and a much better alternative. You can get the inserts welded in for $20 if the control arms are off the car. That set up you linked is a poor bolt on design that appears like they bolt it to the side of the control arm
Old Feb 9, 2012 | 07:27 AM
copper128's Avatar
Lt. Buzzkill (ret.)
That Tamraz bar is a repackaged Addco kit. IMO, Addco stuff is junk. There's no way that flat plate and/or the control arm is not going to flex, plus it looks like dog turd hanging down under the suspension. Just spend a little more to do it the right way. You'll be happier and it'll work better.
Old Mar 5, 2012 | 05:08 AM
beepac98's Avatar
Where do you find "factory" sway bars for '68 oldsmobiles?
I'd like one for my 68 98....
Old Mar 5, 2012 | 05:43 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Actually, factory rear sway bars are still available for Cutlass models from GM Parts.
As for your 98, here's one option:
http://www.realoldspower.com/phpBB2/...=rear+sway+bar
Sorry, the pics disappeared from that post long ago. I saved them somewhere and will post them if I can find them
Old Mar 5, 2012 | 06:08 PM
allyolds68's Avatar
I checked a couple of weeks ago and the A-Body sway bar (Part Number 394926) is no longer available from GMpartsdirect. It may still be available from your local GM dealer
Old Mar 5, 2012 | 06:13 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Bummer.
It was a nice option to use the GM piece. Oh well, lots of aftermarket options for A-body cars still.
Charles Ludwick
Dec 30, 2011 07:14 AM
Maverick
Suspension & Handling
May 12, 2010 05:51 PM
65f85
Oct 16, 2009 10:13 AM
Lady72nRob71
Sep 6, 2009 09:49 PM
