front springs
Old Jan 19, 2012 | 11:41 AM
Paul dodd's Avatar
Paul Dodd, 10 sec Old's
front springs
Hello from London, England, UK. My 10 sec 72 Old's Cutlass Supreme sits too high at the front after serious weight loss, ie glass hood and front fender, ally heads and intake etc. I want to get some lowering springs but not eibach as the car sees street and strip use and i need some weight transfer, any suggestions? I was thinking of cutting a coil off the original springs but have been advised not too, what do you say, and if i go for Moroso springs what spring rate should i go for? Any advice would be appreciated, thanks.
Old Feb 8, 2012 | 09:42 AM
ah64pilot's Avatar
Paul, per my last email...I am going to weigh my car Friday and will call Moroso to get the correct spring rate for that weight. I would imagine our cars would be close to weight, the only real difference being the fenders.
I have Aluminum Heads, Intake, lightweight Holley, aluminum brackets, aluminum pulleys, aluminum water pump, and fiberglass hood. I will weigh my car at both the halfway mark (halfway between front and back wheels) and the whole car. Keep this thread alive and we'll figure it all out.
I want mine to sit just like 507Olds does...I wanna say he told me he used 190 spring rate Moroso's on his. I'm not sure.
bigjaythe1st
Suspension & Handling
May 8, 2012 05:45 PM
1acesmith
Aug 11, 2011 11:03 AM
Devon76
May 31, 2007 05:50 PM
gypsee
Brakes/Hydraulic Systems
Oct 20, 2006 07:18 PM
mcutlass1969
Aug 6, 2006 03:47 AM
