Installing Hotchkis Front Sway Bar End Links
Old Mar 27, 2011 | 04:05 PM
oldzy's Avatar
No mention of this in the instructions at all... but I am assuming I need to connect the end links when there is weight on the car?
As it is now with no body on (and the ends sway bar itself being on 30 degree angle or so as seen in the pic below)... the ends of the long bolts are just flush with the hole in the lower control arm (the bolts were oriented head up and nut on bottom in instructions pics if that matters), and that is w/o the lower washers/poly mounts, making it impossible to get the nut started.
Old Mar 27, 2011 | 04:56 PM
Yeah, they should make right up when the car is sitting on its wheels, though I'm a bit surprised that you can't get the bar to rotate a little bit further.
Old Mar 27, 2011 | 05:02 PM
Ranzan's Avatar
Getting There
oldzy I had the same issue with my energy Susp end links...
I ended up using a wood clamp to compress the end link enough to get the nut stared took about 2 minutes per side
Old Mar 27, 2011 | 05:05 PM
z11375ss's Avatar
Senior Moment Member
I had to drill and tap new mounting holes on the frame because the bar was that much bigger than the stocker. Did you have that too?
Old Mar 27, 2011 | 06:25 PM
oldzy's Avatar
Thx. I will prob to wait until tires are on... or compress it a bit to get the nuts started.
No issues with sway bar mounting holes... I am using the new Hotchkis HD Billet Alum. sway bar mounts for this huge *** 1 3/8" sway bar. There was little to no effort to get bolts started by hand into the stock frame mounting holes. I am hoping it does not get too close to the idler arm. So far though it looks ok, but nothing is tightened yet.
Old Apr 8, 2011 | 12:52 PM
Lalo442's Avatar
Looks good nice pics...
Old Apr 8, 2011 | 12:56 PM
Dave Siltman's Avatar
Boy! That is one clean and well done suspension! I think you'll find that after you re-install the body and driveline the components will fit as designed.
Old Apr 8, 2011 | 03:15 PM
I agree. If the frame mounts are loose, what's stopping you from rotating the ends of the bar downward towards the LCAs?
Old Apr 11, 2011 | 07:35 AM
The Stickman's Avatar
Now that is pretty. I might need a set of those for my bar.
Don Roberto
Jun 1, 2014 06:05 PM
oldzy
Jul 1, 2012 08:05 PM
oldzy
Jan 15, 2012 06:18 PM
oldzy
Suspension & Handling
Dec 3, 2010 08:20 AM
oldzy
Nov 30, 2010 11:33 AM
