Why does it lean?
Old Jan 12, 2011 | 02:47 PM
Stevec's Avatar
Why does it lean?
I have a 68 442 convertible and as long as Ive owned it it the driver side was a little lower than the pass side. I recently put on a complete Hotchkis tvs system and its better but still slightly leans on the driver side. Ive seen other cars do the same. Whats the deal? Thanks! Steve
Old Jan 12, 2011 | 03:42 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Haha, you should see mine. It has a horrible lean and a crack in the windshield from all the repeated launches. In its defense, it only has 1 air bag in the rear though.
I'd examine your body mounts. Driver's side tends to go bad because of the driver being on that side most of its life.
Old Jan 12, 2011 | 03:52 PM
Rickman48's Avatar
One of those 'air-conditioning' hard rubber spacers will make it look right, until you can get to the mounts!
Nephew's '69 Cutlass has the opposite side problem - seems the crossmember's bent!?!
Old Jan 13, 2011 | 10:39 AM
I can get you some solid mounts milled up from Brian for about 6 bucks a piece.
Old Jan 13, 2011 | 11:12 AM
Stevec's Avatar
body mounts
How many to replace em all and is it hard to do?
Old Jan 13, 2011 | 01:53 PM
jensenracing77's Avatar
my dad had got a 70 W-30 used around 1989 that was that way and my Rallye 350 was that way when i got it in 1990. they were both that way till we changed the springs. every time i see it, it is always the driver side.
Old Jan 13, 2011 | 02:05 PM
Indy_68_S's Avatar
I always thought mine was lower on the driver's side, but I never measured it..It just felt that way...
One thing I did read in a post somewhere : Check the rear upper (frame) spring/shock mount(s). Air shocks were put on a lot of old A-bodies... If the shocks were pumped up hard and the car beat on, it would hammer on, and could eventually bend, the upper mount plate....
Archer Meredith
Oct 14, 2013 06:17 PM
Bunser
Jun 12, 2012 10:00 AM
pcard
Jan 25, 2012 07:13 PM
Dan K
Dec 13, 2011 11:03 AM
1973olds98
Jul 18, 2009 03:42 PM
