coil springs
Old Dec 23, 2010 | 09:47 AM
bigwillystyle's Avatar
new user
coil springs
I need new coil springs, but I would like to upgrade them to make the suspension stiffer. Can I order springs for a 442 with a 455 and will they fit in my 71 cutlass S.
Old Dec 23, 2010 | 03:33 PM
Yes they will!
Old Dec 24, 2010 | 09:38 PM
new user
thank ya much
Old Dec 25, 2010 | 07:18 AM
Lady72nRob71's Avatar
See if this post might help you...
https://classicoldsmobile.com/forums...tml#post170009
Old Jan 4, 2011 | 12:57 PM
jag1886's Avatar
A new set of the correct springs will make it ride stiffer. I just put a new set of stock Moog springs in my 65 and it made a large difference.
Old Jan 5, 2011 | 05:25 AM
The new moog springs are stiffer than stock for both the STD and HD sets.
Old Jan 5, 2011 | 07:41 AM
77GCSX's Avatar
How about springs for, say, a 70 Cutlass fitting on a 70 Delta 88?
Old Jan 5, 2011 | 08:13 AM
Check on Rockauto to see if they use the same #'s. If so, use 'em!
I would doubt that they could be used due to the Delta being much heavier...
projectheaven
Jan 31, 2009 05:38 AM
cola
Jun 18, 2008 08:34 PM
cmarshall
Jun 18, 2008 08:31 PM
68conv455
Feb 20, 2008 02:36 AM
mcutlass1969
Aug 6, 2006 03:47 AM
