Tools needed for front end rebuild?
Old Jan 4, 2010 | 02:28 PM
HouTXCutlass's Avatar
Hello Old(s) Friends,
The next project on the old gal is a front end suspension/steering rebuild and front drum to disc brake conversion. I have a floor jack, stands and a decent selection of hand tools but what are some of the other tools I’ll need for this endeavor? Pickle fork? Spring compressor? What about the control arm bushings having to be pressed in/out? Is there a tool for that or is it a machine shop deal? Any little tricks of the trade, helpful hints or on-line links are much appreciated. From other threads I’ve read, I know I’ll need a bigger hammer and to keep the kids out of the area as there will be much cussing involved. Thanks, Rob
Old Jan 4, 2010 | 06:50 PM
hamm36's Avatar
I had a shop press all bushings and lower ball joints. They did it all for $40. I rented a spring compressor from the local parts store (O' Reilly's), for the install. They hold the deposit and return the deposit when tool is returned. I got all MOOG parts from RockAuto.com, and disk kit from CCP. I did this all about a year ago. Let me know if you have any questions. You can do it!
Old Jan 4, 2010 | 07:02 PM
FATRATMATT's Avatar
A good (small) sledge hammer is a must, one with a short handle. Inpact wrench and compressor will make things go better too.
Old Jan 4, 2010 | 08:16 PM
Gary's 2 442-S's Avatar
Gary
When I made the conversion to disk brakes, I also used Moog parts from Oreilly's. The lower ball joints had to be pressed in and the control arms bushings also had to be pressed in. I took them over to a friends house who had some type of pressing tool. I tried using two different types of spring compressors, but I could not get either one to work on the front. so what I did was to take my floor jack and position it under the lower control arms and jack it up enough to where I could bolt the spindles onto the ball joints.Maybe I was using the wrong string compressor.I also did not have to use a ball joint separator because I just whacked the old ball joint on the nut and it released.
Old Jan 5, 2010 | 09:19 AM
While a press (and the special Kent-Moore tools) make it much easier, I have rebuilt many A-body front ends with nothing more than a hammer, bench vice, and some large diameter sockets (or correctly sized thickwall pipe). Of course you will need a pickle fork (actually two different ones) to separate the ball joints and tie rod ends.
The upper ball joint is riveted to the control arm, so grind or drill out the rivets and the ball joint comes off. The replacement will have nuts and bolts.
The lower ball joint is removed with a small sledge hammer. Open the jaws of the bench vice just enough so that the control arm sits on top of the vice but the lower part of the ball joint fits through the opening. Depending on how badly worn the ball joint is, I've been able to wail on the end of the stud and work it loose. Failing that, use a section of pipe that just fits on the upper part of the ball joint housing. Reverse the process to install the new one. I have large sockets that are just the right size for pushing on the outer rim of the new ball joint. Flip the control arm over on the vice, insert the ball joint (I use a little grease on the mating surfaces) and hammer away.
The big problem is always removing the rubber bushings. The force of the rubber pushing on the ID of the sleeve makes it tough to get these out. The easiest (and messiest) method is to burn the rubber out with a torch (propane works) first, then collapse the sleeve with a hammer and punch so it falls out. The burning rubber makes a smokey mess, so you have to do this outside over a metal container. It usually takes lacquer thinner to remove the sooty, oily residue from the control arms. Other folks have claimed success by using a drill or a roto-zip tool to cut the rubber out. I have not tried that method, but it should work.
Reinstallation of the bushings is similar to the ball joints. Use a little grease on the mating surface, then install it in the control arm and hammer away using the correct size socket or pipe. On the lower arms, you need to wedge a piece of wood or angle iron between the two walls where the bushings go so as not to bend them during installation. On the uppers, recognize that the shaft needs to be in place as you install the bushings.
One final trick on reassembly is to be sure the weight of the car is on the springs (suspension at normal ride height) when you torque the bolts and nuts that compress the bushings. This locks the rubber in at a certain position. If done with the suspension hanging, the car will not sit right and the rubber will be overstressed.
Old Jan 5, 2010 | 11:03 AM
Lady72nRob71's Avatar
DOH!!!!!!!!!!!!!!!!!!!............. My luck....
Old Jan 5, 2010 | 12:44 PM
My442's Avatar
Factory service manual is mandatory.
Old Jan 5, 2010 | 12:45 PM
My442's Avatar
I would never use a hammer.
Press only - less chance of damage.
Old Jan 5, 2010 | 05:54 PM
Well it looks like I have my plan of action. I have found a youtube video showing the c-arm bushings being pressed out with short piece of pipe and also one using the torch method. I'll also check some local shops to see what they say. This will also give me an excuse to buy a vice which I've been needing anyway. Any excuse for some new tools! Now if I could just get that compressor and air wrenches that Santa forgot this year . I got all MOOG components at Rockauto. They had the best prices and it's easy to find a 5% discount code by just googling it. I ordered the stuff at 3 pm on Dec 31st and it was at my house via fedex on Saturday morning Jan 2nd. How's that for quick?!?! So thanks to all ya'll for the tips, insights and encouragements and I'll have some pics to go on here soon. Rob
Old Jan 6, 2010 | 07:50 AM
Why? With only cursory care, there is no chance of damage. In fact, I've had more trouble installing ball joints with the "correct" Kent Moore tool than with my hammer and pipe sections.
Old Jan 6, 2010 | 04:44 PM
Joe,
A hammer does wonders in some situations. I printed out your instructions also so that will help with the install. If you're not busy and want to come on down to Texas I could use the help. We do have a cold front this weekend though where our highs will only be in the 30's and 40's. But I'm sure that's considered balmy where you're from this time of year. Thanks again....
Old Jan 7, 2010 | 08:53 AM
Originally Posted by HouTXCutlass
... We do have a cold front this weekend though where our highs will only be in the 30's and 40's. But I'm sure that's considered balmy where you're from this time of year. Thanks again....
Yeah, about 10-15 deg warmer than it's supposed to be here. Where's that global warming when you need it?
Old Jan 7, 2010 | 09:32 AM
Well it looks like I have my plan of action. ...and I'll have some pics to go on here soon. Rob
Please post pictures and perhaps even a write up of the process.
I will be needing to do my front end soon and it is the same style car as yours. I will be doing it by myself and so far only have front suspension rebuild experience on the Ford rack and pinion setup. The GM A body steering is quite a bit different.
Old Jan 7, 2010 | 06:54 PM
I don't know if I could get as detailed as your interior resto chronicle Rob, but I'll see what I can do. By the way, Lady is looking might fine in her glamour shot ....
Rob
Old Jan 8, 2010 | 05:33 AM
Jon sure works wonders with pictures - I give him the credit. The shot he used for my sig was actually the last one I ever thought he could use - it had a complex background. He really is a digital artist!
theoldsrocket
Apr 10, 2013 05:52 AM
72cutlassolds
Feb 8, 2012 03:15 AM
Wireman134
Jul 27, 2008 09:34 PM
Jolly Green
Jun 27, 2008 02:21 PM
Fred H
Jan 12, 2008 05:38 PM
