1968 A-Body Disc Brake Conversion
Old Oct 15, 2009 | 07:00 PM
smcurro's Avatar
Hi
I am working on helping my brother change over his 1968 Buick Skylark from front drum brakes to disc brakes. (I know, it's not an Oldsmobile, but I'm told the spindles, etc are the same)
I have been looking at different disc brake conversion kits and it looks like none of these kits include the bracket that goes from the tie rod end to the spindle. Is this bracket reusable from the old drum brakes for the disc brakes or is a new bracket required?
The bracket I am referring to is circled here:
Thanks for the help!
Old Oct 15, 2009 | 08:01 PM
svnt442's Avatar
If they are designed as a conversion spindle and not factory disk brake spindles then they would have to be able to accept that arm or you wouldn't have any steering.
Old Oct 16, 2009 | 02:07 AM
MX442's Avatar
Yes, you reuse the old ones.
Old Oct 16, 2009 | 03:00 AM
Yellowstatue's Avatar
Talking Halt
Lets call that arm the steering knuckle arm (plane arm?) Are you going with four piston calipers or single piston??
Old Oct 16, 2009 | 07:25 AM
smcurro's Avatar
Thanks for the replies! I am looking to convert to the single piston caliper, the kind that is on the 70 cutlass/skylark/etc
Old Oct 16, 2009 | 09:44 AM
The "bracket" is usually called the steering arm, and it is the same on all 1964-1972 A-body cars. Just reuse the old ones.
Old Oct 16, 2009 | 01:15 PM
smcurro's Avatar
Great! Thanks everyone!
Old May 22, 2010 | 11:54 AM
kurtdaniel's Avatar
yeah,,ive used that on my car and it works perfectly great..i use it and pair it with a nice Sway Bar Link Kit..
Mocephus
Oct 1, 2021 09:45 AM
crazycowboyny
Apr 29, 2014 02:33 PM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
smcurro
Suspension & Handling
Dec 8, 2009 07:09 PM
mrstevek79
May 10, 2008 10:02 AM
