Recommended cold weather work clothes
Old Jan 17, 2009 | 10:28 AM
68conv455's Avatar
Its about 15 degrees outside and I've got nothing to do. I should be working on my cutlass but I know I'll freeze in my unheated garage. Can any of you recommend some cold weather gear for the garage? I'd prefer low bulk, washable, warm, and reasonable $.
Also, how do you clean you mechanics gloves? Oil and greese seem to kill them.
Thanks.
Old Jan 17, 2009 | 11:00 AM
ozoneblue's Avatar
Question work clothes
I start out first with Long Jons then get dressed in street clothes then put on my coveralls Walls Blizzard proof or the $ ones carhart & buy the cheap brown jersy gloves 10 Pair $10 or so then when they get beyond use Trash them By the way I have alot of LH gloves that aren't wore out yet ? Also you can get a box of the latex gloves & put them on first They keep your hands pretty warm under the gloves of your choice
Old Jan 17, 2009 | 02:47 PM
easytobedead's Avatar
Just A BaBy {:
you should look in to forced air heater with carasin.only time you will be cold is geting the carasin!
Old Jan 18, 2009 | 12:16 PM
gearhead1218's Avatar
Kerosene salamaders burn with more smell than LP ones do. But the Kero ones can be temperature controlled better.
As for outer wear. You can't beat Carhart coveralls. They'll keep you toasty. You want a nice set of insulated boots and socks that'll wick away the sweat. Your feet will get cold first. Wear a good hat or hood. Heat rises and escapes from your head the most, so keep you head warm. I like the idea of the jersey gloves for being disposable. But if you're not doing much greasy oily stuff, Mechanix-wear makes a cold weather glove that works pretty well. I have a pair of knock-offs and while they're not the best, they're better than nothing at all.
Old Jan 18, 2009 | 12:35 PM
I'll second the Carhart coveralls. I've had a set for over 5 years and I use them outside on the farm. Just remember to layer your clothes - it's the air spaces that are the best insulation.
Old Jan 18, 2009 | 06:34 PM
Danny Wiseley's Avatar
Friend of mine wears panty hose when he goes deer hunting. Less bulk, and warmer than thermals, he sez. He's not too tall, so he can wear his wife's castoffs, and swears by them. Can get on and off his horse easier that way, too. Personally, I haven't tried them, since most of my outdoor cold work has been with fire fighting gear on.
Old Jan 19, 2009 | 05:14 AM
Lady72nRob71's Avatar
The $50 silk thermal underwear I wore to Finland was made pretty much like pantyhose... I am sure the silk set I had was a little warmer but the concept is to be tight but not restrictive to wick away moisture from the body.
The cheap cotton thermal underwear can get damp during wear from body moisture and then you feel cold and clammy. The more active you are, the wetter they will become.
If you feel damp, you feel cold. Your top layers should be breathable, too.
That silk set I have, along with some good sweats, wind pants, a fleece jacket, wool socks, and polar boots kept me warm at -10*. Adding a ski jumper kept me almost warm enough on some -30* days and nights out on the snowmobiles at high speed... That is all overkill for our main topic here though...
Old Jan 19, 2009 | 05:41 AM
Oldsguy's Avatar
Past Administrator
Kind of on topic - off topic, there is a co-worker here that is Inuit (from Alaska), he wears short sleeve shirts all year round and hardly ever wears a jacket. Something to be said for genes I guess.
Old Jan 19, 2009 | 06:00 AM
71rocket's Avatar
car nut farmer
A good pair of thermals from the sporting goods department(they have the best), a nice heavy and loose sweatshirt, stocking cap, cotton gloves, and mats/carpet to stand and lay on. Seperate your body from the cold concrete.
Old Jan 19, 2009 | 07:03 AM
citcapp's Avatar
The months of April through October works best for me
Old Jan 21, 2009 | 05:32 AM
csstrux's Avatar
Raid wifies pantyhose drawer, cut off the toes. They work well as an underlayer for thermals. I use them in zero and subzero weather under my thermals. Also long sleve t shirts. If you pair them up wit a good set of thermals you will be fine in a jacket, and jeans. Since I tried it last year, I hardly ever have to mess around with my covvies, and manuverability is improved. Helps when you are tring to tarp a load 13' off the ground on snowy material. Biggest risk...funny looks from the wife
Old Jan 22, 2009 | 12:17 AM
mike's88's Avatar
I've got 2 pair of thinsulate lined jeans which have me toasty even in the -30 w/windchill, plus a carhartt coat. One t-shirt, a sweatshirt, and some good socks keep me warm all day long. I only wear 1 pair of jeans at a time also.
Tedd Thompson
Aug 11, 2013 01:51 AM
Bill W
Jan 4, 2013 04:59 AM
Joffroi
Jan 17, 2012 04:23 PM
boondocker
Dec 26, 2010 08:43 AM
