Another Oldsmobile 324 Engine question
Old Jun 2, 2008 | 05:37 AM
sanemb's Avatar
Question Another Oldsmobile 324 Engine question
We got the engine back together, gaskets and everything. Went to prime the oil and we are getting no oil into the rocker arms or heads. The oil goes into the lifters and the front and back of the engine without a problem. So, we have taken the heads back off, and double checked the pistons (everything is fine there). Does anyone have any ideas as to what the problem could be? What we're trying tonight is tearing the timing chain cover off and getting down to see if the cam bearings were installed correctly. We had them installed by the machine shop. Anyone ever had this problem?
Thanks,
Sandy
Old Jun 2, 2008 | 11:18 PM
59-59-59's Avatar
STOP NOW!!!! The cam has to be spinning to force oil up to the rockers!!.. I learned this the hard way on a 394. Also double check there is no blockage of 45+ year old garbage in the oil holes leading up to the rockers thru the heads or block. Spin the crank with a ratchet and prime the engine - do this with no spark plugs in the heads - its a whole lot easier
Old Jun 5, 2008 | 09:31 AM
sanemb's Avatar
Thanks, that was our problem, along with a tad of dirt in the cam bearing holes.
Sandy
Rocketguy
Feb 25, 2014 04:23 AM
coldwar
Feb 20, 2014 01:09 AM
doyle gibson
Nov 19, 2008 08:45 AM
sanemb
May 30, 2008 07:48 AM
Olds Nut
May 28, 2008 06:27 PM
